Can't get stuck tape piece out of player
I have an 8 track player that ate my tape. I have most of the tape out, but a tiny bit is still in the player. I can't seem to get it out. How do I do that?
  • 104 Answers
Wow thats vintage gear i,m impressed , unfortunately you will have to take the unit apart and free it by hand its not that hard to do , then when you get the tape out make sure you clean the capstans so as not to let it happen again [which it probably will anyway ]
hope this helps
Posted on May 24, 2009
How do I fix my 8 track player?
These are operate by a solenoid and a ratchet that moves the head up and down. Pressing the channel changing button activates the solenoid. A metal strip on the tape also activates the solenoid. In this case either the solenoid has stopped working, it might be stuck! Or the ratchet is damaged. Most of the time it sticks on channel 4 with this fault, though it can stick on others.
Apr 08, 2016 | Audio Players & Recorders
How do you get a tape out that is stuck
Probalby the only way to get stucked tape out of a player is in pieces. Then repair the cassette and clean your player. If it keep stcking tapes, dispose it.
By the way, cassette tapes an players are rather obsoleteby now. Any digital source is better quality the a cassette.
Aug 28, 2010 | JVC TD-W118 Single Cassette Deck
I have an 8 track player that is playing the 8 tracks sped up. Also it chews some of the tape on some of them. This is two speaker stand 8 track player, One of the speakers carries the 8 track pocket. ...
Hi , it is good to hear someone in need a help for the 8 track player. I love this player, the mechanism and the sound quality due to the higher speed. Now you will need to open the set and mainly check on the pinch roller. This could be bad and to get a replacement might be difficult. so try to clean using go alcohol based solvent, clean up all the transport track area, the head and check also on the belt. make sure the tapes are not damaged as you will never get a replacement, i suggest that youmust make a copy soon. If the pinch roller bushes are worn out , it can wobble and push the tape down to chew, try to use a light emery paper to even the surface of the roller. I wish you luck and many happy hours of our old favourites. Helpful? Good day
Jun 08, 2010 | RCA Audio Players & Recorders
Won't turn on video tape stuck halfway inside
Stuck halfway inside could indicate that the actual tape is stuck in the capstan/heads. It may have never fully released from the mechanisms and returned to casing. Basically it ate your tape. You could try taking the cover off the unit and manually and carefully remove jammed tape. Unplug the unit first. Hope this is helpful.
Apr 29, 2010 | Sanyo DVW-7200 DVD/VCR
How to install a factory 8 track tape player in a 1967 cama
CANT HELP U W ANYTHING AS OLD AS AN 8TRACK PLAYER MY GUESS IS U BEST BET WOULD BE TO AT SOME SALVAGES FOR YOUR BRACKET
Feb 11, 2010 | Car Audio & Video
I HAVE 1998 Oldsmobile Intrigue WITH A CASSETTE STUCK IN THE TAPE PLAYER
HAHA! When I bought my car two years ago this is what I had too! I just had it all taken out (the unit) and put a c.d. player in it. I do know that if it has ate a tape once, it will do it again.
Jan 03, 2010 | 1998 Oldsmobile Intrigue
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Jun 12, 2009 | Sony Handycam CCD-TR87 Camcorder
8 track player moters run but it doesnt pick up the music.
Sounds like either the head is open circuit or more likely the pre-amp for the 8-track has gone. Follow the leads from the head and it should lead you to the PC board of the amp. Check for broken connections first. You should get the pre-amp to buzz by touching the terminals where the head leads join. As you are getting no sound from either channel it might be the power to the board. But if you see a single IC it might have gone. For the power option (if the channels are seperate) suspect the largest electrolytic capacitor on the pre-amp board first.
By the way if you get a buzz from both channels the head has gone.
Apr 19, 2009 | Audio Players & Recorders
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Cut
I'm no expert but I found a butting the broken bits together and using a small bit of sellotape was good enough to recover the tape. hope this helps
Aug 08, 2008 | Sony Hi8 Hi-8 Tape
75 people viewed this question
 Grubhead
Grubhead
