Kodak m67 movie. Projector
Runs only in rev can't get to run forward
3 Suggested Answers
  • 412 Answers
SOURCE: problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: 760H projector will not go fwd or rev either from
The problem you are experiencing is caused by a broken cycle solenoid "link". The "link" connects the solenoid plunger to the slide change mechanism. Over time, the "link" (made of plastic) gets brittle, cracks and the projector stops cycling. Parts are still available (www.micro-tools.com), but this requires an experienced hand and a service manual. Once done, your projector should be good for another 20 years !!
Posted on Jan 03, 2011
Threading and showing the film
Usaly means that drive rubber bands have gone bad, Very hard parts to find anymore.
Nov 15, 2014 | Kodak Vintage 8mm Eastman Movie Projector...
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Instamatic M67 Movie Projector
I'm not sure what your issue is here. If you are having a functional problem, please describe it with detail and I will attempt to assist you. Jim
Nov 25, 2012 | Kodak Office Equipment & Supplies
Bell & howell 356 projector runs slow
You have this posted in the car and truck forum, please re-post in the correct product category.
Feb 21, 2012 | Cars & Trucks
I cannot get my projector to stop rotating the slides tray. No matter what setting the projector is on, it runs on "fan mode" and keeps rotating the tray. The Kodak Carousel 4400 that I have is...
This problem is caused by the cycle contact requiring an adjustment. Unplug the projector, remove the lamp module, turn the projector upside down & remove the bottom cover. Near the center of the projector is the Slide Change Mechanism. At the center of the mechanism is the Camstack. Refer to the illustration for the correct position of the clutch contact to the cycle pad. You will have to bend the clutch contact wire (GENTLY) a little bit, then plug in the projector & cycle it Forward a few times and check the position of the wire to the pad. This adjustment usually takes a trained hand a few times to get the position correct. If you don't want to tackle it, contact a factory-trained repair dealer for assistance. Good Luck !!jauburn_4.jpg
Dec 15, 2010 | Kodak Carousel 4400 Slide Projector
Problems with using a 140 carousel on a Kodak 4600
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Jul 06, 2009 | Kodak Office Equipment & Supplies
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
44 people viewed this question
k24674
