Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Push start button vaccumm won't turn on
When you push the start button nothing happens
I had a problem with my switch not working. The cheesy microswitch has a little nub on the back that breaks off. They kind of work like a ball point pen. I noticed that if I held my thumb against the back of the microswitch, it would click on and off.
Disassembly:
First, unplug the machine and disassemble the switch housing. There is a screw in the front. It takes a no. 10 Torx driver to remove it.
On the back there appears to be two little tabs that need to be pulled out. Don't mess with them! They are there to fool you. Instead, with a flat tip screwdriver, reach down past the tabs and pry inward (the handle of the screwdriver moves outward, the tip prys inward).
On the front is a little tab that needs to be gently pryed down. The unit should slide out.
With your thumb against the back of the switch, press the button. If it seems to be staying down on one stroke and popping up on the next, continue reading. Otherwise, you may need a new switch.
Now for the fix/jury rig:
With the plastic housing set aside. Put all the wiring and switch in it's place on the vacuum. The switch has grooves that allow it to slide onto the vacuum. Everything should go in neatly.
What you need is a thin piece of wood or plastic, about 3/4" long and 1/2" wide (a popsicle stick would probably work). Slide it between the bottom of the switch and the molded plastic on the vacuum. Make sure it is snug. Try the switch. It should be working now.
Now carefully slide the housing back on. I like to depress the switch first. Make sure the housing snaps back on. It takes a bit of force, but it should slide fairly easily right up to near the vacuum's face. If not you may want to make sure you're not interferring with any wires etc.
Good luck,
bentod
Posted on May 02, 2009
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
Lately, my vacuum will only turn on when the accessory hose is hooked up. If I have the carpet brush attachment in place, the power will not turn on. I noticed that there are 2 switches that need to be...
It is most likely the switch. To be certain, hold the lower switch button on the front in with a small screwdriver and push the switch. BE SURE to push the button in first, and then the switch. If the motor doesn't start, you need a new switch assembly.
Feb 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My volta pet lover vaccumm won,t **** up the dirt and fluff off my carpet. It is also very hard to push when it is turned on.
The product is a load of rubbish. I wouldn't bother to fix it. It does not perform as desired. Scrap it or use it as a boat anchor!
Feb 16, 2011 | Electrolux EL1000A2 Pronto Bagless Stick...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
No vaccuming
Leave it to Cool may have tripped themal switch
Nov 13, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Kenmore 35913 Progressive Vacuum with Direct Drive
If you push the reset, it should push in and if nothing happens, then there is a problem with either your cord, switshes or motor.
May 29, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
149 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
