Question about HP OmniBook500 250MB Zip Drive Module (F200960902) Drive
Verbatim Micro SDHC Card (Class 4) - 4GB - HP OmniBook500 250MB Zip Drive Module (F200960902) Drive
SD card says write protected
There is a small tab on the card that you can move to change this.
Oct 04, 2015 | Lexar Micro Sd Sdhc 4gb Class 2 Flash...
Why isn't my computer reading my micro sdhc card in a sdhc adapter, yet when i plug in a 'normal' sdhc card' it appears in my computer
The PC should be able to see 32GB.
Before the adapter, the first thing to check is the driver for the card reader.
The next most likely: the adapter is bad.
This is also a common problem
Jul 28, 2015 | PNY 32GB MicroSDHC Class 4 Memory Card...
I have an S D card in my android phine. O I still need the MicroSd adapter card?
The adapter is only used for when you need to us it with your computer. Most computer don't have a slot for a micro sd card, and this is why most micro sd card comes with an adapter.
Oct 04, 2014 | Patriot 16GB 16 GB Class 4 MicroSD /...
My computer wont format my micro sd card
Is it an SD card or a microSD card? If it's a 4GB (or larger) card then it's neither, but instead an SDHC or a microSDHC.
If the card is an SDHC/microSDHC then your card reader may be only SD-compatible. If this is the case then you can buy an SDHC-compatible card reader and use that. Alternatively, if you want to use this card with some other device, such as a camera or a phone, format the card in that device instead of in your computer.
Jul 10, 2012 | SanDisk 4gb Class 4 Sdhc Sd Hc Flash...
Hi i got a 32 gb sansa fuze memory card.. like 2 weeks ago. from buy.com and well today i got my sansa fuze white player. the memory card will not fit into the player. I would like to get a memory card...
From your description, you seem to have bought a regular SDHC (secure digital high-capacity) card. A Sansa Fuze can only accept micro SD or micro SDHC cards. For buying a new card, I would suggest this card from newegg.com. As for other things you mentioned: No, the card you bought is not meant for cameras only, the only reason your device uses micro SD/SDHC cards is because it is a smaller device. The 4 on your card signifies that it is class 4 which is the card's speed classification.
Jul 12, 2011 | SanDisk 1GB microSD Memory Card
If the camera says the internal memory is full and won't allow me to take any more pictures, do I need to get a new card reader?
Your camera has only 32MB of internal memory, out of which only 13.5MB only is used for picture storage, which allows you to save only a few pictures. If you need to shoot more pictures you need to buy SD or SDHC cards or micro SD cards. If you buy micro SD card, then you also need to buy an SD adapter. SD adapte is very cheap, usually less than a dollar. The maximum size SD card you can use in Kodak Z915 is 32GB SDHC card. SD card sizes are available only upto 2GB. SDHC cards goes from 4GB to 32GB. Again these cards are rated based on their speed classes. It is preferable to buy Speed class 6 and above for good video recording. With higher speed class, speed increases. If you want to shoot pictures faster then you need higher speed class memory. Price of the card increases with the speed class. You can buy speed class 2, 4, 6, 8 or 10.
If you want to download your camera manual, try the following site:
http://resources.kodak.com/support/pdf/en/manuals/urg00995/Z915_xUG_GLB_en.pdf
Jan 14, 2011 | Kodak EasyShare Z915 Digital Camera
I have just been given a kodack easyshare c143 camera as a gift but i do ot have a memeory card di i ned to purchase one before i can use it ?
For all practical purposes, yes. The camera does have some memory, but you probably won't be able to take more than three full-resolution pictures before it fills up.
The C143 uses SD and SDHC cards. I strongly suggest buying at least two cards so as to have a spare in case you fill up one card or one card goes bad.
Jan 03, 2011 | Cameras
Does not recognize 8gb Verbatim SDHC card
Too many GB`s for this model..1 or 2 GB is enough for hundreds of photos.
Nov 30, 2009 | Canon PowerShot S2 IS Digital Camera
I bye verbatim micro SDHC card 4GB but i can't pot the song in it .Why?
Most phone will not allow you to simply transfer Mp3s directly to your phone as they will not read the format. Please respond with the make and model of your phone and perhaps I can be of more assistance.
Nov 30, 2008 | Cell Phones
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
