Question about Fantom Vacums Vacuums
How do I clean the Collection Bin and the cone screen
Hi I have a lightweight phantom bagless vacuum. Wondering if I can rinse the filter with water?
Posted on Nov 14, 2014
The shroud on my dc59 is full of dust is there any way of cleaning it
Hi Marian, it's Jack at Dyson.
It's normal for harmless static to cause fine dust particles to cling to parts of the cyclone pack after use. This won't affect performance as the airflow doesn't need to pass through this dust.
It's not possible to remove the mesh shroud, but you can clear any fluff or clinging debris from the shroud after removing the clear bin. In order to do this, press the red bin base release catch once to open the bin base. Then with the base still open, press the same red release catch firmly a second time to disengage the bin.
You can then use a dry cloth or soft brush to remove any debris from the fine mesh shroud. Please don't attempt to wash or submerge either the clear bin or the cyclone pack, as this could cause damage not covered under your Dyson warranty.
I hope this information is useful, but you're welcome to get in touch with our experts if you'd like further guidance. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 06, 2015 | Dyson Dc50 Ball Multi-Floor 2-Tier...
My Eureka 5892 BVZ-1 vaccum has very little suction. I checked hoes and emptied cup, and made sure filter is not dusty.
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Mar 04, 2011 | Eureka 5892AVZ Bagless Upright Cyclonic...
Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Dyson dc05 takes the dirt up the cyclone cone instead of spinning it in the clear cannister and blocks the top filter within a few minutes??
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bin inner is missing. If you remove the bin and cyclone assembly from the machine and then seaprate the two pieces as if you were going to empty it, you should have a coloured piece of plastic in the bottom of the clear bin with a large black rubber seal around the top. If you dont, you will need to purchase a new bin assembly via our website at www.dyson.co.uk or via our Helpline on 0800 298 0298.
Kind regards
Darran
Dyson Customer Service
Jan 19, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
Electrolux Z8240 model vacuum cleaner flashing red & blue 1 every 6 seconds. What could be wrong with it
Inside ,the dust collection container, there at the far end is a white cone shape (another filter). I think you may find this covered in lint etc and if you reach in with your hand you can just pull the stuff off. Happened to me around the two month mark and I THINK, so far, so good. My machine is now not switching off and flashing lights at me and the suction is back to fabulous. Found this information on another obsure website. You would think electrolux would mention it in their "Troubleshooting Guide" GOOD LUCK
Oct 02, 2008 | Vacuums
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Vacuums Logo
57 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
