Question about Bosch & Tankless LP Hot Water Heater
Model gwh1600H - Bosch & Tankless LP Hot Water Heater
  • 30 Answers
Whats the problem? Make sure you have rebuilt your watervalve(gets done every 3-5 years) if it doesnt get done, the unit will probably not light, or light intermittently, and you'll have wild temperature fluctuations
Posted on May 06, 2014
Year model by serial number
So.........it's a GSW 50 gallon which you either bought in Canada or smuggled in.
Even if you have a model with a shutter damper without a fan this is NOT a Power Venter and will need standard through roof flue pipe/chimney to establish draft and vent CO and exhaust gases atmospherically AKA Natural Draft. It will NOT vent sidewall without a fan induced draft
Sep 07, 2014 | Water Heaters
No hot water no flame gwh1600h bosch
Tell me more! --
Do you have any other gas appliances in the house?-- and they are firing OK? Can you hear the gas flowing when you push in on the ignition start button? -- There should be a spark as you 'snap' the button?
Remember-- YOu get no ignition of the big flame, until you have water flowing--
How old is the heater?-- Could there be come obstruction in the water flow sensing device?
Oct 13, 2013 | Water Heaters
Temperature
Pull the thermostat loose from the wall so you can see the model number located on the back of device.
Google search model: xxxxcy .pdf
Or search for british gas thermostat .pdf
This will give you access to product manual.
Also check batteries located on back of unit. Install fresh batteries. Memories should be retained on the chip during battery change.
Add a comment with model number, and I will try to locate thermostat manual.
May 20, 2013 | Water Heaters
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Richmond 5v40-36f
1) My search does not show that product exists, or existed before the internet.
Maybe that product only exists on fixya.
Or the water heater is older model number from Rheem., aka Richmond, Ruud etc.
Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank.
It might also be older manufactured home gas water heater.
Feb 07, 2013 | Audiovox Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
I have a Model 41V50 Rheem water heater (50 gal. natural gas) and needs to be replaced. However, I can't find this model at any of the local stores. Has this been discontinued? If so, what can I get for a...
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
Jul 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Bosch & Tankless LP Hot Water Heater  Logo
41 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
