Question about Brother DCP-7030 Digital All-in-One Laser Printer
Toner Problem. I just replaced my toner cartridge for my DCP-7030 printer but I keep getting a "Toner LIfe End, Replace Toner Cartridge." Now the printer will not print. What should I do?
  • Anonymous Mar 15, 2014
    toner reset dcp 7030
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
Posted on Apr 24, 2009
Toner life end replace cartiage solution
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Aug 21, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Toner life end replace toner catridge message on the screen
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and give you time to purchase a new tonercartridge for your printer. A cheaper alternative is to purchase are-manufactured toner cartridge for your model printer.
Feb 24, 2011 | Brother DCP-7030 Digital All-in-One Laser...
DCP 7030 printer says toner life end, replace toner cartridge. After replacing the toner printer still gives the same message and will not print.
What worked for me was to follow the instructions in this video: Resetting lever on cartridge There is a lever on the left hand side of the toner cartridge (left hand side - with you holding the cartridge as if you were going to insert it into the printer). It seems that lever has to be at the '12 o'clock' position to tell the printer that you have a new cartridge. The video showed the person removing 3 screws and then ensuring the lever was at the '12 o'clock' position. On my cartridge I had to do some wiggling to get the lever to move as it's gear assembly seemed to want it to only move down to the '4 o'clock position' and then stay there. Eventually I got it moved to 12 o'clock - and when I stuck the toner back into the printer - the 'toner end of life' message went away. I then removed the toner cartridge - as I wanted to try another cartridge that I had also reset the lever on. I found that lever had again moved to the 3 or 4 o'clock position - after printing just one test page so I am guessing it being at the 12 o'clock position tells the printer you have a new cartridge - and then it moves over to the regular position at 3 or 4 o'clock..
Feb 01, 2011 | Brother DCP-7030 Digital All-in-One Laser...
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Brother 7030 printer drum end soon problem
that's not a problem, the printer warns you when your toner is soon to end. Get a new cartridge to replace it when it is all used up. Tip: Toner warning comes on early, you can get more pages out by taking the drum out and shaking it carefully.
Nov 03, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Replace cartridge error
i have brohter dcp7030 laser printer .earlier toner is empty si i refiiled the toner but toner giving me not printout.printer is display the message of toner end so plase me suggest the reset of this ptinter
Oct 28, 2010 | Brother DCP-7030 Digital All-in-One Laser...
I have a printer dcp 7030 brother company i am showing problem toner life end after reffling
I just had this problem and fixed it. The original toner cartridge that comes with the printer cannot be reset. You have to buy at least one new cartridge. The reason is that the original cartridge that comes with the printer doesn't have a reset flag. You can, however, refill/reset a cartridge that you buy separately. Pull out the drum and lift the cartridge out of the drum. Hold the handle and look on the left end. You should see a crescent shaped hole with a white flag/lever. To reset this, move the white flag all the way to the left (I had to use something to push it). Put it back into the printer and voila - it fixes itself. Then, after the printer has been reset, you can use the original cartridge again, if you want. The flag part won't matter once the printer has been reset. I hope this is clear. I know it worked for me, and I had the exact same problem.
Jul 14, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Brother DCP-7030 Digital All-in-One Laser Printer Logo
1,791 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
