Question about Kodak Office Equipment & Supplies
Printer smudging i am printing out plain black writing and when it comes out of the printer the writing looks smudged almost like it has been printed twice. i have go onto the menu and selected clean pin head and then did a test page but that didnt do anything. what could i do to sort it out?
  • 514 Answers
Sounds like the rollers are contaminated/ and or the print heads have stuck on them. you can use alcohol on a cotton swab to clean them.
Posted on Oct 14, 2013
babb
  • 104 Answers
SOURCE: Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
Posted on May 10, 2007
  • 49 Answers
SOURCE: black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Posted on Oct 08, 2008
  • 5 Answers
SOURCE: HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Posted on Nov 28, 2008
Drachnem
  • 34 Answers
SOURCE: smudges on items printed
Take the cartridge out and shake it, when you do this thought make sure you cover where the toner goes out of or you'll make a mess! I had this same issue with my laser printer and this resolved it.
If that doesn't fixya then you may want to clean the rollers you can buy sheets to run in them.
Posted on Jan 20, 2009
POCBM
  • 121 Answers
SOURCE: 4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Posted on Apr 07, 2009
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
Gray smudge on edge of paper
If you get only black smudge even when you're printing in color your problem is most likely the black cartridge. If it smudge in colors look at your transfer belt, open the front door, the big belt that hangs on the door.
Dec 02, 2010 | HP Color LaserJet 2600n Printer
I got smudges when i print ,how can i clean this
It looks like you've managed to get some ink on the rollers. 3 Possible solutions:-
1) Check your printer maintenance menu, there may be a roller cleaning option.
2) Print a document which has printable data on almost all lines, but with empty cartridges. You'd be using a piece of paper more or less as a mop.
3) Final alternative, it getting right into your printer and cleaning it by hand. Printer ink is water soluble so damp cloths/cotton buds should be man enough for the job. The parts you need to concentrate on are the rollers and the small sponge wells underneath where the print cartridges rest.
Apr 13, 2010 | Computers & Internet
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Jan 14, 2009 | Epson Aculaser C1100 Printer
Black ink smudges for color print mode only, not for grayscale
Oct 08, 2008 | Samsung CLP 300 Laser Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
52 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
