Question about Vacuums
I have two oreck xl type 7 vacuums. One of them is extremely loud. I think it's caused by the motor spinning too fast. Is there a way to slow down the motor? Or maybe it isn't hooked up correctly?
    Genius:
  • Vacuums Master
  • 1,166 Answers
Most likely problem is a broken impeller fan which causes it to be loud because it is out of balance
Posted on Nov 01, 2013
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 5 Answers
SOURCE: My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Posted on Oct 15, 2008
WonderTech
  • 268 Answers
SOURCE: While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
Posted on Aug 20, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
Sparks coming from under oreck vacuum. looks like its coming from motor brushes.
Probably need to have that serviced at a repair shop. They can tell you whether or not you need a new motor or a fan blade kit.
Feb 21, 2013 | Oreck XL Ultra Bagged Upright Vacuum
There are sparks coming from the underside of my oreck xl vacuum.
You probably need to take that in and have it serviced at a repair shop. They can check the motor to see if it needs to be replaced or just cleaned. The noise could be bad bearings or a fan problem as well.
Feb 21, 2013 | Oreck Vacuums
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
XL2525 changing motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=723450
Posted by geoffjackie on Jun 30, 2008
Please forward the wiring instructions for changing the motor in my Oreck XL 2525
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Oreck factory for the wiring instructions but you need to give them the model # and the serial # if needed and I will supply you with the Oreck website and the cust serv phone # listed below. Also, you can check the owner’s manual and sometimes there is a schematic that shows you if information you need for changing the motor. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Vacuums Logo
49 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
