Question about ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300
What means sb pwr
What means exactly sb_pwr
  • 374 Answers
'SB' stands for StandBy. When the motherboard is connected to the power supply but not turned on the SB voltages are supplied to different parts of the motherboard. In some motherboards you are able to charge devices like Phone without powering on the computer, that's because of the SB.
The SB in turn triggers other voltages used for the motherboard.
Posted on Nov 03, 2013
    Master:
  • 359 Answers
I believe that stands for Southbridge, the chipset that communicated with the PCI, USB, IDE, ports etc. The Northbridge is for the CPU, RAM and AGP every other device will communicate through the Southbridge.
Posted on Oct 13, 2013
2 Suggested Answers
  • 245 Answers
SOURCE: what means exactly SB_PWR ,I know PWR means power
try google.com ...
Posted on Oct 18, 2013
Sb pwr light keeps on / one beep and the PC turns off
Check that keyboard is plugged into correct port.
Can you Enter CMOS setup ? Try replacing battery on main board.
Oct 21, 2013 | Intel Computers & Internet
I need a manual so I can set-up board HD LED, PWR LED PWR BTN, RST BTN SLP LED/BTN, etc.
Here you go! :)
http://download.intel.com/support/motherboards/server/s5000pal/sb/d31968004_s5000pal_userguide.pdf
Cheers!
Oct 28, 2010 | Intel S5000PALR Motherboard (891957) USB...
Dryer keeps blowing fuse
yes, after years of current going thru the fuse clips they get hi resistance connectiond and cant supply correct pwr to dryer and this results in blowing fuses especially the time delay fuse because this fuse supplies pwr to both the one side of heating element and the motor simutaneously -replace with a breaker sub panel if not enough room for a circuit in your main panel,that should solve your problem
Jul 13, 2009 | Dryers
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
Need pin settings
Dear S_Proheartdt,
you can download the complete manual for this motherboard from this site, it will really helpful to you:
http://www.intel.com/support/motherboards/desktop/d845ebg2/sb/CS-008633.htm
Be Happy Always
Regards
Dec 03, 2008 | Intel Desktop Board D845EBG2 Motherboard
Fans comes on for 3sec
Here are a couple of things...heres the Intel site about this board, with connections (with a very clear front panel drawing) diagrammed:
http://support.intel.com/support/motherboards/desktop/d850gb/sb/CS-013238.htm
and here is a page of pictures of this model board to compare to youre to make sure it is the same board:
Jun 04, 2008 | Intel Desktop Board D850GB Motherboard
ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300 Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
