Question about Electrical Supplies
What does valves set on 16 hp 9000 generator
    Master:
  • 452 Answers
12thou in let.......14 thou exhaust.
Posted on Oct 15, 2013
3 Suggested Answers
  • 396 Answers
SOURCE: I've got a Power Pro By Wen Power Model 9000 16 HP
Check the gas cap. There is a vent to allow air into the fuel tank as the fuel is drawn out. If this vent becomes clogged, a vacuum can be formed in the tank. This can prevent gas from flowing to the carburetor.
Listen carefully when you remove the cap. If you hear a "whoosh," there likely was a vacuum.
Posted on Oct 17, 2009
GBELECT
  • 23 Answers
SOURCE: I have a Wen Power
Rob
When was the last time this generator was run,allot of times they lose their magnetism from sitting so long? Also you may want to check your voltage regulator to make sure it is putting out the correct voltage..
Posted on Aug 06, 2011
A powerhorse 9000 generator the electric starter will not crank with the key. have replaced the solenoid . Can also jump the solenoid and the starter cranks. Is there a fuse on the starter circuit?
manual says there is a fuse, but only covering the 12 volt DC output. There is a number where you can call them on page1.
[PDF]MODEL 9000 16 HP Generator - WEN Products
www.wenproducts.com/store/index.php?route=product/download/download...id...Thank you for purchasing a model 9000 generator. This manual ... Please keep this manual available to all users during the entire life of the generator. 04/06 ...
Questions? Problems?
Please call our customer help line:
(800) 232-1195 M-F 8-5 CT powerhorse 9000 generator manual Google Search
Aug 12, 2017 | Powerhorse 166114 9000w Portable Generator...
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
Steele 9000 watt generator won't start
Hi Derrick
I assume you can turn over the engine, and the engine has run previously?
Check for spark, -take off the plug lead and connect an old spark plug to the ignition lead open the gap up to about 5/16 inch . Tie the thread of the spark plug to the engine to hold it and earth it with a bit of soft wire. Wind over the engine you should get a nice fat blue spark. If you get a nice spark do you can eliminate ignition issues. This just leaves fuel. You can then focus on this.
Jacko
Apr 13, 2014 | Steele Products 9000 Watt Portable...
Brand new 9000 watt steele generator won't start
Try a little starting fluid in the intake. If it starts with that, then it is a fuel problem. Make sure the fuel valve is open on the bottom of the tank or at the carbureator, if there is one.
Apr 13, 2014 | Electrical Supplies
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Toyota Corolla Cars & Trucks
1992 saab 2.3 16 valve 9000 turbo starts and quits real fast please e-mail Dave
test the fuel injectors with a noid light type into you tube to watch a video on how to test fuel injectors with a noid light
Apr 04, 2011 | 1992 Saab 9000
I have a Wen Power Pro 9000, 16 HP Generator. Couldn't run my coffee maker this morning. Used a multimeter and was only getting 35 volts. Is it brushes or something more complicated. Rob
Rob
Dec 27, 2010 | Watts Onan Portable Generator - 4000 ,...
I've got a Gen Pro 9000 watt gen with a 16 hp Vanguard will not charge the battery
this may be due to a bad voltage rectifier it should look like a small box with wires coming out of it. Disconnect and have it checked
Dec 09, 2009 | Electrical Supplies
I've got a Power Pro By Wen Power Model 9000 16 HP Generator - kicks on with one pull however shuts down after about 10 min of operation. I've changed the oil and cleaned the air filter. Any other...
Oct 17, 2009 | Watts Onan Portable Generator - 4000 ,...
MR. Heater Portable Buddy model MH9B
the mr heater series units have a millivolt generator connected to a very small sensitive electromagnet in the valve body. inside the generator is a small insulated wire connected to the very tip of the generator. that and the outside copper tube forms the j-k junction. at the other end, the part that goes into the valve is a silver button and a gland nut. this forms the other part of the electric circuit. the inside of the valve has a spring and an iron slug with a rubber pad. the slug gets sucked into the electromagnet when the magnet is operating and holds the pad off its seat allowing propane to go through the regulator and valve. change out your generator and I'm sure your problems will be solved. mr heater has a web site.
Oct 29, 2007 | Heating & Cooling
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
