Question about Samsung ML2165W - ML-2165W Wireless Laser Printer
How to connect wi-fi printer to laptop - Samsung ML2165W - ML-2165W Wireless Laser Printer
    New Friend:
  • 3 Answers
With a wireless router that you probably have for you laptop. Printer should be connected directly to the router, and all PC's in you home can use it as a network printer, so everyone can print on it. Whether connection between printer and router is Wi-Fi or cable is of no importance.
The procedure of installation may be a little boggling for someone doing it the first time. As I remember you should start installing driver CD on you laptop, and it will tell you when to connect printer to it, and when the basic part of installation is over. This way you can use printer connected directly to you laptop via USB.
Next it will offer you to set wireless parameters. If your router is set to automatic (DHCP) it will ask you to register printer on your home network and you must enter your wireless network SSID and password somewhere in your printer. It should not be too hard. You just have to fallow the instructions.
If your friend comes over with a laptop and joins your wireless network, he still can't use your printer, because he's hasn't got drivers installed, so you'll have to do that part all over again, for every PC.
Posted on Oct 13, 2013
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Lenovo 3000 N100 (0768-A53) 15.4
if you have wifi then set your printer to wifi enable and connect with your computer, no need of bluetooth
May 21, 2012 | Computers & Internet
My dell inspiron 531 is not wi fi compatible how do I hook up my lexmark x4550 printer/scanner/copier to it
bring usb wi-fi from market it will turn your computer to wi-fi capable, other wise you need usb cable to connect printer with you laptop and drivers as well..
Nov 01, 2010 | Lexmark Office Equipment & Supplies
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
Print from laptop without using router to lexmark 6600 wifi printer
only if you get a wi fi access point and have a switch to connect the wi fi access point to but then you would have issues with NAT ( Network Address Translation ) which is used to be able to connect many computers to the internet through one internet connection.
Apr 30, 2009 | Office Equipment & Supplies
Mcafee
McAfee has controls that can lock you out of the internet. Are you trying to connect via wi-fi or ethernet cable? If it is wi-fi, try disabling McAfee, connect to your wi-fi then turn it back on. You'll need to make an exception for that connection. If wired, disable McAfee, make an exception for port 80, 8080, 23.
Apr 18, 2009 | Acer Computers & Internet
Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Oct 10, 2007 | i-mate K-jam Smartphone
Samsung ML2165W - ML-2165W Wireless Laser Printer Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
