Question about Sony Televison & Video
Sony klv 46w550a lcd tv has vertical lines colour striations across screen. gets worse after set has been on for a while but sometimes gets clear if channel or input is changed
legna
  • 53 Answers
SOURCE: my lcd tv is cracked
If you mind the lines and if they are too big replacing the screen will be very expensive and there is no way to repair your current display. The way I see it if you pay more 65% of the current value of your TV is too much. You may be able to find a new TV for as much as the repair cost.
Posted on Aug 28, 2007
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
  • 19 Answers
On an LCD TV? Sounds like you've got a bad TCon board.
Posted on Feb 21, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
SOURCE: Westinghouse 32" LCD - Vertical Line across top of picture
i had this same problem, it ended up being a loose connection on mine, attached picture is where the connection was loose, i took off the back panel and just reattached it, and it was good as new.e87b8ee.jpg
Posted on Jul 28, 2009
My Sony Bravia KDL-46W-5100 has developed vertical lines. Any advice would be most appreciated.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 07, 2016 | Sony Televison & Video
The picture shadowed by vertical lines but the video running smoothly on my screen as the picture below this is BRAVIA TV LCD SONY TV KLV 46W550A
Jun 28, 2016 | Sony Televison & Video
Sony faults
this could be your t-con board, but knowing sonys it most .likely your main panel meaning your screen,
Aug 17, 2014 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
I have a Sony Wega KLV-30HRS3. It powers up ok, but the only thing that comes up is a multitude of coloured vertical lines. The built in graphics still work, ie the Menu page and the channel number in...
Hi there are a few things that could be bad on this TV. the first thing I would check is the T-con board if that's not the problem then the signal board and last the screen itself. If you are planing on doing it yourself you can get parts from www.interliquidparts.com
Jun 02, 2011 | Sony WEGA KLV-30XBR900 30 in. HDTV-Ready...
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Blue line - screen
Your control board and address circuits need to be examined. This could be a component problem or a simple fix such as installing a new ribbon cable from the control board too the address circuits on the LCD panel itself. To do this would require a technician, but before this issue gets worse you should have it repaired.....check to see if its under warranty.
Some people have tapped the back of their tv and got rid of vertical line interference. But , I wouldn't suggest that method.......
Feb 26, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Apr 08, 2008 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Televison & Video Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
