Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Frequencies I have a lpf on my head untit and i have an lpf on my amp. The amp is powering subs and I know the lpf is supposed to be on. My question is which lpf should i use the head unit one or the amps or both, and what frequency should they be set on? one more thing the head units lpf has a -24Hz to +6 Hz for 50Hz, 63 Hz, 80hz, and 100 Hz.
  • ronnieyannon Apr 24, 2009
    Thanx for the help.
  • 655 Answers
Hello again ronnieyannon,
It's probably best to allow the amp that is powering the subs to control the frequencies going to the sub(s). I would not use the lpf on both the head unit and the amp in any case. The control settings are not completely precise and you could end up with a lot of tweaking between the units to get the sound you want. I'd send full range to the amp and with it playing something with a lot of bass, set the 401s to "LP", the crossover slope to near maximum, and then adjust the frequency until it sounded best to me. Starting on page 11 of your manual are the Rockford-Fosgate recommended adjustment procedures, including setting the gains and the filter frequency.
Those numbers for the lpf on your head unit sounds like it allows you to decrease (-24dB), as well as increase (+6dB) the bass at the specific frequencies of 50, 63, 80 and 100Hz. You probably don't want to decrease the bass boost for subs. And the 401s will allow a boost up to 12dB and is variable from 50-250Hz.
Hope this helps.
Posted on Apr 24, 2009
The recommended settings for a mofet car amp 50.4 , theres a few knobs not sure what they should be turned to
The gain knob is used to control how much the volume (output) of the amp increases with each increase in volume on the deck (installed in the dash). This is used to match speakers running of your deck. Other knobs are probably for a crossover (labelled in Hz). This controls what frequencies are passed to the speakers connected to the amp. A Highpass (HPF) crossover passes all frequencies above what the knob is set for. A Lowpass (LPF) pass all frequencies below what the knob is set for. A HPF is typically used when the amp is powering component or full range speakers to keep the ultra low frequencies (anything below 90Hz) from going to theses speakers. A LPF is used when the amp is connected to a sub. Subs dont handle higher frequencies very well.
Nov 02, 2013 | Crossfire Car Audio & Video
How do u know if A sony xplode XM-552ZR amp is on and how do u connect it to a sony xplode cdx-gt570 head unit.
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Nov 03, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
Mtx 801d amp turns on but no bass just high pitch sound sub is fine
if theres a switch on ur amp that says LPF Full or HPF put it on LPF for low pass frequencies
Mar 16, 2010 | MTX Thunder 801D Car Audio Amplifier
What do hpf and lpf switchs do
Hello rwalinske, The abbreviations "hpf" and "lpf" stand for High Pass Filter and Low Pass Filter. They do exactly what their names imply. They allow frequencies above or below a specific setting, while blocking or attentunating frequencies below or above the setting. There's also a "band pass filter" which allows frequencies within a specific range below the high setting and above the low setting. Finally there's a "subsonic" filter which blocks inaudible frequencies below the threshold of hearing. The hpf is generally used in speaker component systems to send the high frequencies to the tweeters. The lpf is normally used with subwoofer systems and is set to send frequencies below the setting to the subwoofer. While most amps will amplify a wide range of frequencies, they are more efficient when the range is limited depending on their intended use. For example, a typical 2-channel amp might have a frequency response of 20-20KHz. When used to drive a set of normal speakers, you would not use either the lpf or the hpf, but simply let it send all frequencies to the speakers. But when used to drive a subwoofer, and operated in "bridged" mode, the amp can put all of it's amplifying power into frequencies than can be used by a subwoofer if the lpf switch is turned on. Hope this helps.
Jun 05, 2009 | Sony Car Audio & Video
Sounds like the amp is playing on full range instead of low
Sometimes the deck needs to be programmed to send only sub frequencies to the sub out. Check the manual or play with the settings. Most likely there is a way to turn it to a sub and a separate setting to change the crossover frequency.
If this is not working, there may be a problem with the Head Unit. If you have another amp in the system, try the sub out in the full range amp AT LOW VOLUME. If not you can use headphones and some alligator clips. Be careful you do not short out the output. Place one alligator on the crown of the RCA plug and one on the post. On the other side, place the crown clip to the connection on the top of the plug and the post on the tip of the plug. If this way you can see if indeed there is full range in the signal. You should here some voice, but not a lot, and a bunch of bass.
If there is too much frequency on the line after these steps then the head unit is not filtering properly and there are two things to be done. Repair or replace the unit. Or circumvent the filtering problem with either an in line RCA Filter or an electronic crossover.
May 15, 2009 | Kicker XS50 Car Audio Amplifier
More power output to sub
I don't know what kind of Amp you have, but you have to bridge the channels together.....For example, on a 2 channel amp you would just take the + wire from the Left channel and the - wire on the right channel and run it to the speaker. This uses the combined power from BOTH channels and funnels it right into the speaker. I hope you have a low frequency filter "LPF" adjustment. In case you are unfamiliar with this term, LPF is a function that most top-shelf amps have which will cut out most all mid-range and all high-range frequencies and put out only LOW (BASS) frequencies......At any rate, since you have a 4 channel amp, to bridge all 4 channels is a little more complicated so I am not going to elaborate too much information as of now only because I don't want to confuse you, or give you the wrong information pertaining to the wrong type of amp and have it blow up as a result of confusion....But you can bridge 4 channels typically in a similar way
May 13, 2009 | Kicker Solo-Baric L5 Car Subwoofer
HPF and LPF problems
it would be best to contact the retailer for the headset and get better assistance for this.
Dec 11, 2008 | Sony Ericsson W200i Cellular Phone
My Sub Doesnt Sound Good
The settings are all pretty much dependent on your ear. But some guide lines would be for the input gain, never turn it all the way up. Turn the gain up about half way possibly 3/4 of the way up. There should also be a filter, if you are powering subs then you want to filter out any high frequencies. So if there is a switch saying HPF or LPF you want LPF (Low Pass Frequency). Then there should be another "knob" that controls the frequency. At the least, you want your sub amp to be tuned below 50 Hz any lower is up to your ear. I hope this helped.
-Andrew Hawkins
Mar 28, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Just want the lows
Hi MC,
Have you tried setting the LPF lower. This is the low pass filter and its setting only allows frequencies below its setting to pass. Also you might have a switch that needs to be set to LPF.
Nov 23, 2007 | Car Audio & Video
Amp
I think it's a bad switch
Jul 07, 2007 | Pyle Blue Wave PLA2740 Car Audio Amplifier
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
119 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
