Question about Sanyo Televison & Video
Sanyo model dp32640
Tv while in any input will flash off fer approx 1to2 sec and come right back on. Any sugg?
4 Suggested Answers
javswr
  • 44 Answers
SOURCE: my inputs dont work
I don't believe the moving and unhooking was the issue! First I would look inside to see if the ribbon like cable came loose,that goes from signal board (input board) to lcd controller. The lcd controller will be on the back of the lcd screen, you will see a small board under a metal cover.
Second It may have been a coincidence, and the signal board was starting to fail. There could be some visual issue's with board maybe some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). Good luck, I hope this was helpful!!
Posted on Mar 01, 2009
  • 5102 Answers
SOURCE: where on the tv do
Get an adapter: the one you need depends on the headphone type. If you have the standard IPod/computer headphones with a 3.5 mm plug, get a 3.5 mm F to RCA stereo (2 male plugs). Then plug the RCA plugs into the audio out of the TV and the headphones into the 3.5 mm end.
The TV's Audio out is between the Composite Video IN (Video 1) and the PC input.
If you want to have a longer cable, get the 3.5 mm F to RCA stereo (2 Female ends) adapter. Then connect a stereo audio cable to the TV audio out and the RCA side of the adapter and the headphones to the 3.5 mm port.
Make sure that the TV outputs to the external speakers (some tvs do this automatically when external speakers are plugged in). Menu > Sound
I hope this helps.
Posted on Sep 20, 2010
  • 1779 Answers
SOURCE: do I need a convertible
No you do not. If your on cable, just screw it in turn the set on and auto-program it. All Done.
Posted on Nov 26, 2010
Sanyo DP32640 LCD TV volume will suddenly spike to full, last 3-4 secs., shuts down, restarts at the original settings, holds 5-10 mins., repeats at 5-15 min. intervals
Set has a poltergeist in its main board where you have the setting electronics. Prices have dropped to such a point on this size set that it is simply not worth a repair.
May 05, 2017 | Sanyo Televison & Video
Was watching tv and it cut off by itself and wont come back on
Hi Angela it sounds like you should contact the manufacturer of the TV, Sanyo on (800) 877-5032 or by email (support@sanyotv.com) even if your warranty is expired they may be able to help you.
Apr 10, 2014 | Sanyo Dp32640
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
Tv shuts off
You may want to check the below article for a wide list of Sanyo models exhibiting "random turn off" problem along with repair options for them.
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
All in all the first thing you need in order to get meaningful help is providing information about which particular model and chassis is your TV.
Both are on the label at the back.
Mar 19, 2014 | Sanyo Dp32640
Remote codes for a DP32640 tv with a GE universal remote
i think you can get a replacement remote from www.tvassist.co.uk. if you can't find the remote you need listed then contact them. These are not universal remote though they are specifically built for your model no.
Sep 08, 2013 | Sanyo DP19649 LCD TV
Sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
Jun 06, 2012 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
