Question about Cobra Radio Communications
Cobra microtallk PR 240-2 radios. One of the radios transmits and receives on a frequency one channel less than the selected/displayed channel. That is, if channel 7 (462.7125 MHz) is displayed, the radio transmits/receives on channel 6 (462.6875). This is true for all channels. This was confirmed using a frequency scanner. The two radios communicate with each other if the one is on ch 7 the other on ch 8 for example. Can the frequency and channel be aligned?
    Genius:
  • Cobra Master
  • 1,795 Answers
I'm looking at a price range somewhere in the area of 40 - 120 $$ to buy them new. If YOU can fix them without getting a tech involved then go for it but you will need a frequency counter that covers the range and they don't give them away cheap and the repair cost wouldn't be cheap either. I would buy another pair.
Posted on Jul 16, 2015
SOURCE: my radio off frequency
is this set AM and the recievers FM? if so there will be no way round the 'problem' BOB
Posted on Apr 19, 2007
  • 19 Answers
SOURCE: Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Posted on Aug 15, 2007
informatica
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
thetez
  • 32 Answers
SOURCE: My superstar 3900 transmits on one channel and receives on one ch
Ok! well i deffinitally know what the problem is. You need to play with the clarifier, i think all the way to the left is a "course and fine tune" knob. This is generally for use when talking on SSB. but may affect AM if its way off.
The clarifier lets you slide on the freq. some radios will go a full channel some will only go a little or above the center of the channel. You need to play with the clarifier, you probably need to turn the course a lot, untill the audio is almost clear on the channel you want to talk on, than use the fine to tune it in so it sounds like they are sitting right next to you.
what you should do is buy a Frequency counter, you got a nice radio, so the freq. counter wouldent hurt. lets say you want to be on channel 19. you would turn the clarifiers untill i read 27.1850 That would put you right on the money
Posted on Jan 13, 2009
  • 773 Answers
SOURCE: Cobra 148 won't stay on frequency, same frequency on all channels
If you have a frequency counter, and a set of TV repair tools,( a set of special screwdrivers) You can tune the transmit on it. I would not do this unless you are skilled in such things.
The easy thing to do is take it to a cb shop. Usually you can find them at truck stops. They usually charge $30 for an alignment.
If you think you can handle it, I can try to talk you through it.
Posted on May 01, 2009
Cant transmit on Cobra PR 4750 WX.
It sounds like you have a shorted RF output transistor.
Apr 22, 2015 | Cobra Radio Communications
Cobra microtalk Cxt135C one radio seems to be muted, there is no sound coming from it at all -
Check to see if you have "tone squelch" or CTCSS enabled. It will only receive transmissions from stations that are transmitting the tone your radio has selected.
Oct 15, 2013 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra 29LTD Classic RX seems to go off frequency. Transmit is fine, but can't receive on same channel. i.e. TX on Ch 11, but RX some other frequency. Was talking to my wife and suddenly, her signal was...
all functions of the radio are performed by the main IC 2816c . The frequency is controlled by this also and if it is blown you will loose your frequency and the problem that emits is in your statement.
Oct 23, 2011 | Cobra 29 LTD CB Radio
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
My radio transmits and recieves very well. My antenna is matched perfect. But, when someone talks, it sounds like bleed over from another channel. Like they are off channel. It sounds the same through the...
Sounds like you need your radio "ALIGNED" by a tech. Not much you can do. Does everyone sound off frequency? If so....theres your problem!
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Dec 17, 2010 | Cobra 29 LTD CB Radio
How do you turn it on
Press and hold the power switch until you hear a series of beeps. The switch is on the top right of the radio, opposite the antenna. Need the manual? You can download and print it here:
http://www.retrevo.com/support/Cobra-PR-240-2-way-Radios-manual/id/8932dj296/t/2/
Bill B
Oct 30, 2010 | Cobra MicroTalk PR 240-2 (7 Channels)...
I need to tell what channel i'm on there's 240 channel's i can only reconize 40 of them
purchase a frequency counter. They are usually cheap. Try ebay. Get one for under $50.
this will give the the frequency you transmit on when you key it.
Nov 15, 2009 | Connex 3300 240-Channels Base CB Radio
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra MicroTalk PR-3550WX - Static after transmission
Dear sir, try to operate ur radio in different channel ,( ur operating area seems to be have so dense radio smog ..if u are located near some border where ur adjacent frequency is in use this cud be the problem .
first try in low power channel ( 8-14) ..if it solves ur problem ok ur u try to contact ur seller , & get it replaced if its under warrenty period.
Regards
raj
May 26, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Radio Communications Logo
75 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
