Question about ASUS RTN56U Wireless Router
Client list asus RT-N56U not showing blocked client list
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: RT-N56u cannot detect wan ip address.
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device
hope this helps
Posted on Nov 21, 2011
gmtuleman
SOURCE: I have a new ASUS RT-N56U that will not find the
Mine used to do this every day. everything would work on lag only, with no internet access. it was an issue with dns server disconnecting and not reconnecting, which resulted in me loosing my internet. i was able to reconnect by reseting power on cable modem, and when it was rebooted i reset power on router. that would get me going temporarily. I ended my problems by doing a factory reset, then updating to the latest firmware from asus website. I also changed my dns settings from auto to google dns servers. The router works 100 times better since doing this stuff and i have had 0 issues since. Your millage may vary. if you don't have a driver or hardware issue, this may help you out. can't hurt to do any of the things to find out. good luck!
Posted on Dec 18, 2011
I have set my Asus RT-N12 to repeater mode, have captured the WiFi source signal, have connected my Client router with CAT5 cable but can't get internet from the Client router.
can you provide a diagram similar to this
I am doing CNNA so this was created with Cisco Packet tracer which is only available to Cisco Students
Sep 25, 2015 | ASUS RT-N12 Wireless Router
Block website
go to your router settings (by typing 192.168.0.1 into your browser) and look for your firewall settings which is what is blocking the websites. if all else fails just reset to default settings.
May 06, 2013 | ASUS WIRELESS ROUTER |WL-520G - RT...
hope this helps
Nov 21, 2011 | ASUS Rt N56u Wireless Router Ieee 80211n...
Printer connected to a Asus router RT-n56u via usb port System with Windows 7 Ultimate 64Bit Usb port enable through Asus Printer Utility Driver select (auto) during installation SAMSUNG UNIVERSAL PRINT...
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Jun 19, 2011 | Office Equipment & Supplies
I have a new ASUS RT-N56U that will not find the WAN through my comcast modem. ANy ideas? Faulty device? I've updated firmware, checked cables and done fresh starts from a powered off state. Thanks, ...
Jun 13, 2011 | ASUS Computers & Internet
Hello! I have a router Asus WL520g and I need to unblock port 8000,I try in router menu/NAT Settings/Virtual Server how to unblock this port but I`m unlucky,doesn`t work.I need to explain me step-by-step...
Port 8000 should not be blocked by default. It may be that your Internet Service Provider (ISP) is blocking this port on their servers. You should call whoever your ISP is and check to see if they are blocking the port.
Feb 28, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS RTN56U Wireless Router Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
