Question about Liebherr Refrigerators
I have two Liebherr Fridge Freezers. The first is a ICN 3056, it failed after 2 years with a loss of the refrigerant. The second ICN 3066 has now lost its refrigerant after 5 years service. Is this a common fault with Liebherr products ?
    Scholar:
  • 50 Answers
Deston, I hate to be the one to break this to you but...the standard of quality and control over the board of appliances is no where it used to be or needs to be. Turning out a well build product one can be proud of has been replaced by pure profit motive. Having said that ANY refrigeration system that looses its coolant befor 8 to ten years has manufacturing / design problems. And I see this in all most all makes and modles.
Posted on Oct 13, 2013
  • 32 Answers
SOURCE: Liebherr refrigerator leaks water
clean the drain tube that drains water to the evaparation pan under fridge
Posted on Oct 20, 2009
  • 7 Answers
SOURCE: freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Posted on Apr 19, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
Bat1956
  • 585 Answers
SOURCE: refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Posted on Dec 16, 2009
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
Freezer temp shot up & then fridge temp shot. Not cooling either compartments now.
Sounds like a loss of freon and this is better handled by a service company or it
could be a relay issue.
Sep 29, 2015 | Liebherr KIKNV3056 Bottom Freezer...
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Very noisy Liebherr CN4013-21 - 4 years old
Might be, the compressor is loose, now is it loose at base where it is fastened or the bearings are loose.
Dec 16, 2013 | Samsung RS2630WW Side by Side Refrigerator
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Feb 04, 2010 | Liebherr KES4260 Refrigerator
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Refrigerators Logo
360 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
