Question about Maytag Dryers
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the belt is wrapped around the idler pulley. Wrapping counterclockwise keeps the belt in contact with the motor pulley but wrapping all the way around the idler pulley makes the belt too short to get fully around. Wrapping clockwise leaves the belt too long and it also does not contact the motor pulley at all. Need advice.
    Problem Solver:
  • 12 Answers
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Posted on Oct 22, 2013
5 Suggested Answers
  • 23 Answers
SOURCE: replacing belt, can't seem to get belt tight. Need to know how to wrap belt around pulleys.
You can find the belt routing for your Maytag here:
http://www.repair-help.com/kb/index.php?article=105
If it won't tension, perhaps you have the wrong belt. The correct belt can be purchased from your local source or this website.
For those of you with other Brands of dryers start here:
http://www.repair-help.com/kb/index.php?category=13
Note: After unplugging dryer; The belts for most regular dryers are accessed by removing the front panel.
Wash and Dry and put the clothes line away!
Posted on Apr 25, 2009
SOURCE: drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
Posted on May 12, 2009
marka19
  • 1430 Answers
SOURCE: Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Posted on Apr 09, 2010
jumptrout51
  • 3361 Answers
SOURCE: how do i access the
We must have a model number to be specific.
Posted on Sep 17, 2010
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
My dryer squeaks terribly
Hello & Welcome to FixYa
Squeaking sound from the dryer comes when the belt is either broken or worn out, before replacing the belt also check the idler pulley because if that is bad then it also needs replacement with the belt. Please get back to me if you have any other questions.
Kevin
Dec 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Washer works fine dryer does nothig
Looks like my Maytag. My dryer belt is broken so doesn't tumble. Check by taking two screws out of tilted panel and look at belt. If it isn't heating probably heat coil. If nothing probably electrical. Maybe door switch is open circuited.
Jan 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
The dryer on my maytag stacked combo lse7804ace the motor works but the dryer doesnt spin. Broken belt?
You will need to either re-install the belt or replace it. I would assume that it's broken because it's not that common for it to just run off the pulleys.
Oct 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer/dryer fills with water, makes noise like it's working, but won't agitate, but at the end of it's cycle pumps out but won't spin either. Is this a belt problem? If so how hard is it to...
Definately sounds like the belt is off. Not too big of a problem for small hands mechanics. Usual problem lately with Maytag is the spindle pulley. For some reason they haven't been tightened properly and the pulley and belts are falling off. Pull it out from the wall remove the panel and see what you've got, really simple on the bottom end. Complicated stuff is up in the control panel. Make sure you get the pulleys lined up as close to level as you can or the belt will jump off on you during spin cycles. Good Luck!
May 10, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Stacked W/D SE 1000
Had the exact same problem. Just had a repairman look at it. I need to replace the motor. Probably won't.
Jun 09, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
114 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
