Question about Dryers
Whirlpool Duet gas dryer has a gas odor. It's not from the gas line, I shut off the valve between pipe and line and it went away. Opened valve and odor surfaces again. Machine drys well, just concerned about the smell and potential leak. Any help?
  • Angelo Cocchiola
    Angelo Cocchiola Oct 13, 2013
    Mod# GGW9250PW1 & odor occurs when machine is NOT running.
  • Whirlpool
    Whirlpool Oct 14, 2013
    Hello Angelo Cocchiola, we are very sorry to hear about the concerns you are experiencing with your dryer. Please email us directly at Whirlpool.Digital@Whirlpool.com and include your name, phone number, address, and the complete model and serial number for your dryer. Please also include this reference number: 61478. Sincerely, Ashley
  • Dryers Master
  • 2,113 Answers
That means that your gas valve (actuator) in your machine needs to be replaced. Don't use it until it is fixed.
Posted on Oct 15, 2013
watugot
  • 290 Answers
SOURCE: Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
  • 1028 Answers
SOURCE: Whirlpool LGB6000KQ1 gas dryer not
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Posted on Nov 27, 2008
Healeyman
  • 1198 Answers
SOURCE: my whirlpool duet gas dryer (model ggw9200lw1) is taking too long
There is a rare chance that the gas supply is clogged. Dealing with gas pipes is dangerous business, don't fool with it unless you are experienced with plumbing. After checking a gas pipe, do a bubble check for leaks with dish soap from a sponge or sprayer. There are small filters and traps placed here and there in the plumbing of some units. They are similar to the ones on a washing machine hose, but smaller.
Posted on Jan 10, 2009
  • 221 Answers
SOURCE: When drying clothes in my gas dryer, you can smell
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Posted on Jan 17, 2010
I have turned off main gas line to dryer and have checked that and the connecting line to dryer and see no leakage but I still have an odor of gas in dryer itself. what should I check next?
check the line inside leading to the flame igniter and glo bar, how did u check for gas leak? just smell or sight? try using a mixture of water and dish detergent by spraying it on the lines while gas is on, and if u see bubbles u got gas leak?
Sep 05, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Strong burning odor from dryer. It went away then is back today.
Hi. pull your dryer out from the wall and remove the vent pipe. Check inside the lower rear of the dryer for lint in the beginning of the exit pipe and then throughout the entire pipe. This can cause a fire so clean this before you use it again. J.
Jul 10, 2010 | Whirlpool ET8CHEXSQ Dryer
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My duet front loader will fill with a large
there are two water valves above the soap drawer, that are sping loaded to stay shut when power is off. if the water pressure to the machine has increased, sat due to an increase in main pressure from the water board fixing a leek further up the supply, then this could force open the valves. try turning the stop valves at the inlet pipe end, away from the machine, down a quarter turn and see if this stops it.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have unplugged the appliance and am wondering if I need to turn off gas . If I turn off gas I will need to re ingnite my hot water heater which is in a very tight spot. However, my life is more imortant....
In most gas dryer installations, a local shut-off valve is required. This means that behind the dryer, there should be a shut-off valve JUST for the dryer.
Now that you have the machine unplugged, slide it forward a little... not too much ...be careful of the gas connection.
There should be a gas shutoff valve .
For gas valves, when the handle is in line with the gas line (when the handle is parallel to the pipe or flex line, that means that the valve is open and gas can flow thru. IF THE HANDLE is at a 90 degree angle from the pipe, or flex, it's off.
Once the gas valve behind the dryer is off, you can disconnect the dryrer's gas line without shutting the gas off to the rest of your home. That way you'll not need to relight the pilot on the water heater...
K
Sep 15, 2009 | Whirlpool LGB6300 Gas Dryer
My whirlpool duet gas dryer (model ggw9200lw1) is taking too long
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
FAILS TO IGNITE ,UNPLUG &REPLUG AND WE HAVE IGNITION
suspect coils on gas valve they will breakdown after several ignitions and not open valve for burner to light
Nov 18, 2008 | Whirlpool LER7646E Dryer
Burning smell
We had the same problem. After we used it a few times, the smell went away.
Jul 06, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
299 people viewed this question
Top Dryers Experts
