Samsung 900x Ultraportable Laptop Ultrabook Logo
Jill Clark-Biller Posted on Oct 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Get this message upon boot up of samsung ultrabook: z:\WinClon\Manager1.exe The system cannot find the drive specified.
Chris Smith
Level 2:
New Friend:
  • Expert 100 Answers
  • Posted on Oct 13, 2013
Chris Smith
Expert
Level 2:
New Friend:
Answers
100
Questions
Helped
51964
Points
205
Sounds like u got a virus. My suggestion is don't open up any mail or any sites that your not sure of.
  • Jill Clark-Biller
    Jill Clark-Biller Oct 13, 2013
    I don't have a problem opening any messages. I can't open anything. My computer won't boot up but thanks Chris
3 Related Answers
Anonymous
  • 145 Answers
  • Posted on Nov 25, 2010
SOURCE: windows cannot find 'x:\WinClon\Manager1.exe'. what is
ok so it can't find it. what problem are you having with your computer??
if no problems.... may I suggest a copy of Ccleaner by piriform ....you can down load it for free @ Cnet.com ... **** cleaner should be used weekly...
Go to downloads at that site.. please only accept Ccleaner by Piriform its free
Anonymous
  • 3940 Answers
  • Posted on Jan 25, 2011
SOURCE: windows can not find x:\winclon\Manager1.exe what
See post #3
http://newyork.ubuntuforums.org/showthread.php?t=1648714
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Jun 17, 2011
SOURCE: I have a Samsung
Welcome to Fixya
Sounds like you have a corrupted operating system. That is also the reason why it is not loading up. Usually using the F4 function will restore the computer back to the factory default state. X: is the recovery partition drive. Manager1.exe id a file to restore the computer. Looks like that this file is missing already that is why the computer cannot proceed further. The only solution left is to use a recovery disk. Call samsung tech and request for recovery disk. You might need to use external Cdrom drive to use the disk and boot the computer. This disk will reinstall Windows to your netbook.
Hope i provided you the information you need.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2answers
My screen is blank and says manager cannot reboot
screen on what? Why can't people put enough info to answer a question? Are you talking about Windows, and the Windows "boot manager"?
here are some fixes to try:
(located here: https://neosmart.net/wiki/bootmgr-is-missing/) I recommend working from bottom up, and trying system restore...unless you have a boot CD/DVD ...in which case try startup repair first.
<Donna> https://everythingit.us
This repair method works if you have the Windows installation disc.
Here are the steps to fix the BOOTMGR error with an installation CD:
  1. Insert your Windows install CD
  2. Restart your computer and boot from the CD
  3. Press any key when you see the "Press any key to boot from CD or DVD" message
  4. Click Repair your computer after selecting your language, time and keyboard method
  5. Select the drive of your Windows installation and click Next. The standard drive is usually C:\
  6. Select Startup Repair
  7. Wait for the process to finish
Fix #3: Use bootrec.exe to rebuild the BCD
bootrec.exe is a tool built in the Windows Recovery Environment (Windows RE) that you can use to troubleshoot and repair the error.
bootrec.exe can repair boot configuration data and master boot records. BCD, which stands for Boot Configuration Data, contains boot configurations options and controls how Windows is started.
Here are the steps for accessing bootrec.exe to rebuild the master boot sector:
  1. Insert your Windows 7 or Vista install disc
  3. Press any key at the "Press any key to boot from CD or DVD" message
  4. Choose Repair your computer after you select the language, time and keyboard method
  5. Select your Windows installation drive (usually C:\)
  6. Click Next
  7. Select Command Prompt in the System Recovery Options box
  8. Write the following command and press Enter:bootrec /rebuildbcd
Fix #4: Run System Restore
The next solution will work only if you have System Restore enabled on your Windows.
Here are the steps for restoring your PC with System Restore:
  1. Insert the Windows 7 or Vista install disc
  2. Restart your computer and boot from the install disc
  3. Press a key when "Press any key to boot from CD or DVD" message appears on your screen
  4. Click on Repair your computer after selecting a language, time and keyboard method
  5. Select the drive where you installed Windows (usually C:\)
  6. Click Next
  7. Select System Restore from the System Recovery Options box
  8. Follow the System Restore wizard instructions to select a restore point
  9. Restore your PC by clicking Finish
Fix #5: Use bootrec.exe to fix the boot
The partition boot sector is stored on the hard disk drive and contains the necessary code to start the Windows boot process. If this partition is corrupt or not properly configured during a Windows install it would lead to "BOOTMGR is missing or corrupt" errors at startup.
This method needs a copy of your original Windows installation disc.
Here are the steps to fix this error using the bootrec.exe tool, the same tool used in Fix #4 above:
  2. Restart your computer and boot from the disc
  6. Click Next
  7. Select Command Prompt from the System Recovery Options box
  8. Write the following command and hit Enter: bootrec /fixboot
  9. Wait for this message to appear: The operation completed successfully.
  10. Restart your computer
Samsung np530u4c error boot
Tap F2 while powering up, enter BIOS and check boot settings order. Maybe it's become set to boot from CDROM first. HDDs should be set to AHCI formats. Try booting from CDROM anyway if you have an operating system on disk.
File folders from my usb cannot be opened unlike individual files which can be opened. upon opening a message from trend micro office scan appears, as follows: plug in device (usb)...target:...
Try to right click the drive and go to properties. On the drive properties window, click on security tab then change the permissions from there.
Hope this helps.
5helpful
Windows cannot find 'x:\WinClon\Manager1.exe'. what is mean??
Samsung SP0411N HDD, error message while booting shows "Pri Slave Drive - ATAPI Incompatible" "Press F1 to resume" [email protected]
Hi guies ,
                   you haven't specify which kind of error message displayed on screen ,please  do same
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
