Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
An older stihl fs80av weed trimmer that was made in japan and has a tk carb. How do the fuel lines attach?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Stihl doesnt make equipment in japan either america or germany
fuel lines attach to carb
Posted on Dec 30, 2013
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
Where do I attach the stop switch wire on a Stihl FS36 weed trimmer?
one end goes to the switch the other end goes to the ignition module
Jan 04, 2013 | Stihl Fs36 Line Trimmer Gas Tank
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Weed eater wont start
If you haven't changed fuel filter in awhile, do that as well.
look here...
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Stihl fs200 weed trimmer starts hard. coil problem?
Dirty fuel filter, dirty carb, dirty air filter.
Spend 1.50 at walmart for QuickStart fuel starter fluid.
It is ether - and will start any working engine quickly.
Suggest adding about 1/2 oz of fuel system cleaner (also available at walmart automotive section) to clean up the fuel system.....
Choke works, I assume.
Nov 01, 2009 | Garden
Stihl FS 110 brush cutter loop trimmer ''weed eater'' won't start. I've changed gas and spark plugs and it still won't start. Tool is 5 years old. Help! D.W. from NC
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
May 18, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
124 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
