Question about Garden
Stihl fs80av I have an older tk carburetor model stihl made by shindaiwa fs80av weed trimmer. the carb has two feeds. how do these fuel lines get installed. one is obviously the fuel pump feed the other main fuel feed. However the fuel tank has a either a primer bulb and or its some kind of purge/check valve that has only one fuel line that goes into the tank. How are these line routed? Is there just a tee there? The flow of fuel is making no sense to me.
    Sergeant:
  • 322 Answers
Generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Posted on Oct 17, 2013
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
dontbother10
  • 2220 Answers
SOURCE: saw repair
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Dec 07, 2009
dontbother10
  • 2220 Answers
SOURCE: Primer bulb-carb routing
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 10, 2010
197jacobs
  • 226 Answers
SOURCE: I have a 2250 Poulan. The fuel lines have been
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Posted on Dec 29, 2010
How to line the feed on Stihl FR 106 Weed Eater Max 420 head
could you add a picture of the particular head you're using.
Aug 22, 2014 | Stihl FS 85 Weed Eater
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
I need a carb kit installation guide for my Shindaiwa n452 hedge trimmer
There is no guide. Post the model and manufacturer of te carburetor itself. Walbro, zama, tk, etc.
Sep 20, 2013 | Shindaiwa N452
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
How to proceed starting a homelite weed trimer for the first time in over eight years.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, @@
Dec 31, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
I have an older Weed Eater gas powered trimmer(Model XT 85T) The fuel lines have aged, rotted and broke. I have new lines (big fuel line and small fuel line). How do I get these lines through the holes...
gas line is 1/8" ID. NAPA autoparts sells replacement gas line that works but has an OD that will not fit hole in plastic frame where the carb sits. Just drill the plastic to the OD of new gas line and use needlenose pliers to install the line. Same goes for the gas tank. Just make sure it is tight fit so it does not leak.
Mar 27, 2009 | Garden
Garden Logo
598 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
