I have dell inspiron n5110 get charging problem sometimes then after a week my display becomes dim. I can able to see that my display is working with without brightness. I connect it to external display it working properly. Please fix my problem
    Sergeant:
  • 324 Answers
Is the brightness ok if the charger is connected to the laptop and dull when the charger is not connected - also what operatng system are you using ???
Posted on Oct 17, 2013
  • 5 Answers
SOURCE: Dell Inspiron 2200 loose DC power pin connector
hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Posted on Feb 17, 2008
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 6 Answers
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
Posted on Oct 22, 2009
jesselohse
  • 128 Answers
SOURCE: dell inspiron 1318 lcd screen completely dim
The backlight in your LCD has gone out. You will need to replace the entire LCD. You can look on ebay or here, you will be paying around $300 for it.
Good Luck!
Jesse
Posted on Jan 05, 2010
potek18
  • 528 Answers
SOURCE: Booting with External DVD for Dell Inspiron 1525
you need to go to the bios. and change the boot/start menu there.
when you start your pc. press f2 continuously and you will see a blue screen. go to start/boot using arrow keys. make sure that the num 1 priority is externall hdd or usb
Posted on Mar 30, 2010
I was changing the power connector for my dell inspiron n5110 but one part came out c7001 now I don't know the location
It's the bluetooth card goes by the speaker cable on the front of the motherboard see images on this page http://www.insidemylaptop.com/disassemble-dell-inspiron-n5110-inspiron-15r-laptop/
Apr 08, 2014 | Dell Computers & Internet
Dell Inspiron N5110 i7 home premium
You can get it here on Ebay.http://www.ebay.com/sch/i.html?_trksid=p3984.m570.l1311.R6.TR12.TRC2.A0.XDell+Inspiron+N5110+&_nkw=dell+inspiron+n5110+screen&_sacat=0&_from=R40
Jan 24, 2014 | Computers & Internet
My dell inspiron n5110 cd-rom is not working
go to control panel and use the utility restore system, and put the the last days that you know was working good and ready.
God bless you
Oct 29, 2013 | Dell Inspiron 15r N5110 Pc Internal...
L_not_less_or_equal erroe
Try to connecting it to an external monitor and see if you you get the same error. If so then your graphics board or circut has a problem.
Jun 29, 2013 | Dell Inspiron 15r n5110 Laptop
No sound
you can download it here
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-15r-n5110
Aug 02, 2012 | Dell Peacock Blue 15.6" Inspiron N5110...
Sudden shutdown
Remove main battery and run the laptop, if it continues to work without shutting down that is a indicator the battery needs to be replaced.
Apr 05, 2012 | Dell Inspiron Computers & Internet
I forgot my password on a dell inspiron N5110 laptop
i forgot DELL INSPIRON N5110 ADMIN BIOS PASSWORD......HELP
Jan 19, 2012 | Computers & Internet
Dell inspiron display very dark, brightness turned all the way up Using external monitor works fine .
check your power settings in the display you probably have it set to be dim when not plugged in when battery is under a specific charge. hope this helps
Mar 13, 2010 | Dell Inspiron 1300 Notebook
Computers & Internet Logo
David Payne
David Payne
