Question about Electrical Supplies
Coleman powermate 5500
Will run great but get no power from the outlets
    Master:
  • 452 Answers
Check master switch some times it burns out if that checks out ok Alternator will need checking out ,
Posted on Oct 15, 2013
  • 13 Answers
SOURCE: no power out put
this may sound silly, but check the reset breaker buttons
Posted on Sep 20, 2008
CarlGehrke
  • 169 Answers
SOURCE: motor runs but have no power coming out of outlets of mygenerator
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
Posted on Nov 29, 2008
mamicheddy
  • 79 Answers
SOURCE: engine runs but no power aat outlet????
Start with brushes and rings. Make sure your rings are clean and the your brushes have a good length. Flash the fields with 12V battery. Apply positive to the brush nearest the bearing and negative to the back brush, while genset is running. Use rubber gloves when doing this and keep hands away from rotating parts. You should see the voltage climb when you flash the fields. This would mean that you need a voltage regulator. If voltage does not climb, then you will need a new genset.
Posted on May 17, 2009
sal_kh_sab
  • 98 Answers
SOURCE: Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Posted on Nov 23, 2009
How do i excite my 6250 powermate and where can i buy parts. Runs great but no power at all. Thanks John
One quick way to "excite" the field is to plug an electric drill into the outlet of the running generator. Engage the trigger on your drill and spin the chuck backwards. DO NOT HAVE YOUR FINGERS WRAPPED AROUND THE CHUCK WHEN DOING THIS. IF IT WORKS (not 100%) THE DRILL WILL START UP!!! Coleman was bought out by Pramac, you can find there webpage here.
Hope this helps.
Feb 22, 2011 | Coleman Powermate Premium Plus 6250W...
Excite the genset.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
next is...brushes..
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
