Question about Altec Lansing Audio Players & Recorders
Altec lansing sr4021 making loud crackling noise
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
  • 341 Answers
SOURCE: Scratchy loud noise when volume dial is turned
It means that the volume pot is dirty.You need to find a way to get some WD-40 into the pot.This usualy requires that you take the access to the inside off and spray right inside the pot.Once you do this move the volume dial from min to max a few times and it should fix it.
Posted on Jan 05, 2009
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
darktowernz
  • 222 Answers
SOURCE: Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Posted on Dec 06, 2009
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Why does it emit a loud whistle when turned on?
I got rid of my Altec Lansing because I got white noise when the unit was turned OFF. They are not a good make. You can try moving any wires or magnetic influence away from them. I now own Bowers and Wilkins MM1 speakers which are amazing.
Bowers Wilkins MM 1
Mar 14, 2016 | Altec Lansing New Original Dell ADA995 5.1...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
My subvoofer burs
Induced noise - running signal wire too close to electrical cables.
Faulty/damaged Input reciever (jack) on subwoofer - test by isolating PC, and attaching iPod or other device to check for noise instead.
If the noise is not present when using the isolated source, your sound card output jack is bad, or the soundcard itself.
Thank you for using FixYa - A FixYa rating is appreciated!
Jan 26, 2009 | Altec Lansing ATP 3W Computer Speakers
Speakers Died?
No, I think you've fried only the fuse of Altec Lansing. Check at the back of the main unit (subwoofer) if there's a fuse box (should look like head of the plastic bolt). If not than turn it off, unplug it and open op the main unit and check for the fuse. It should look like this:0a68355.jpg
If the metal wire inside of it is broken than you should buy new fuse of same amperage (it should be engraved on metal part of the fuse or printed on glass tube).
Apr 21, 2008 | Altec Lansing ACS 45.1 Computer Speakers
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
48 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
