Question about Xerox Office Equipment & Supplies
Xerox colorqube 8570 paper jam sensor - Xerox Office Equipment & Supplies
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
SOURCE: My Xerox XC 1045 copier's paper jam indicator is lit, however I have cleaned and searched thoroughly for any jam but cannot find one.
Hi
Replace or clean paper eject sensor and chek
Dileep
Posted on Nov 05, 2008
  • 75 Answers
SOURCE: We have a paper jam on our Xerox 6180. It jams on
Please Call this number for this solution, details is given below.
Technical Support, Manuals and Documentation - 1890 925 050
Note - Access drivers, downloads, manuals, documentation and the online support knowledge base. Please have your serial number handy.
Thanks for using Fixya.
Anand
Posted on Mar 30, 2010
Smith-alone
  • 360 Answers
SOURCE: xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Posted on Jul 19, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Posted on Aug 10, 2010
Xerox 8570 tray2 issue pickarm stuck
the problem of your machine is mechanical you must change your gears found on your machine.
Sep 06, 2016 | Xerox Corporation Xerox ColorQube 8570DT...
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
What does error code 91,721,00:3959 on a xerox colorqube 8570 mean
That error is a printhead tilt fault. The printhead is not able to cam back and forth correctly. There is a kit that fixes that problem, part number 8570-Z1. http://www.iteminconline.com/itemdesc.asp?ic=8570-Z1&eq=&Tp=
Aug 26, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
Reset maintenance kit on a xerox colorqube 8570?
There is no "reset", except to replace the Maintenance Kit. That will reset the life back to 100%
Apr 10, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Phaser 8570 makes grinding noise
Our Xerox 8580DN is making a grinding noise when starting up and then it doesn't start up it state that there's a jam.
Mar 12, 2013 | XEROX - COLOR PRINTERS COLORQUBE 8570/N...
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
1,242 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
