When I loaded and started ASKO W 6561 washing machine, it started as usual. But when I later went back to see if it was done, I discovered that it had stopped midway and saw the error message "Fault indication Water Outlet fault." What does this mean and can it be fixed easily and if so, how? If not, what should I do?
  • 175 Answers
It means something stopped the unit from draining normally. nine times out of 10, this is change in the drain pump cleanout. it's the littloe square panel on the lower left of the front of the machine. you pop that open with a screwdriver, and remove the end of the black small hose attached to the door and stick that in a bucket. it will drain most of the water form the machine. after it is done, unscrew that little circular cover and pull it out. it will probably be filled with all sorts of fun stuff and change. clean all of it out and put it all back together, making sure to put that small black hose back on the little nub it came off of. check again and see if it works, If not, you may need a new drain pump. Good luck! P.S. If you have the owners manual, or can find it on askousa.com, it has pretty clear instructions how to clean out this trap, It's considered user maintenance by asko.
Posted on Nov 10, 2013
4 Suggested Answers
  • 351 Answers
SOURCE: Asko W640 Front Loading Washing
may be carbons in motor and or board
Posted on Aug 27, 2008
SOURCE: Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Posted on Feb 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
Asko W600 extra rinse button not working
some can be taken apart and inside is a spring loaded connection that pushes the button back out sometimes hard water and soap and debris can jam and stick the spring and u get what ur getting? you may be able to by pass the extra rinse by disconnection the prongs to it and taping them up?
Mar 29, 2015 | Asko W600
High limit thermostat
A year ago, I needed to replace a high limit thermostat, and I received ( for the money) both the high and the low!. I replaced the high therm., and a month later, the low one went out. I discovered these need to be replaced as a pair only.
Be blessed.
May 16, 2014 | Asko T761 Electric Dryer
Who do you set timer on asko 6461 washer?
the timer you are trying to set is for a delay start. so if you set the timer for 1 hr, the machine will start 1 hr later.
Feb 05, 2011 | Asko W6461 Front Load Washer
Replacing Motor Brushes, what needs to be done to clean commutator for a Asko 10505 Washing Machine sold in Australia - purchased around 1998 - ignore the W6021 system wouldn't let me post.
To clean the commutator, or armature as it is usually called, simply rub it with a piece of emery paper, or sandpaper, turning it by hand to ensure you clean it properly..
You need to remove the motor to do this of course.
Please rate my solution.
Thanks.
Nov 12, 2009 | Asko W6021 Front Load Washer
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
