Question about Audi 2.8 Timing Belt Kit A6
How do I set timing for nissan sentra 1,6 twin cam
  • 635 Answers
Get the factory repair manual it shows diagrams and walks you through the procedure.
Posted on Oct 14, 2013
What is cylinderhead bolts torque settings
follow this link and click on torque tables then look up your vehicle
http://www.speedwayautoparts.com/index35.htm
Jul 22, 2014 | Nissan Sentra Cars & Trucks
Nissan Sentra 2005 wont start when cold, change fuel pump, change crank and cam shaft still same issue
Make sure it did not jump timing.
Set cylinder 1 to top dead center (TDC),make sure the two timing dot on the cam line up.
Jan 13, 2014 | Cars & Trucks
What is the proper timing on 95 Altima 2.4 twin cam
1995 Nissan/Datsun Altima 2.4L SFI DOHC 4cyl
The Ignition Timing20 Degrees
Aug 22, 2013 | 1992 Nissan Sentra 4 Door
Nissan sentra 1.6 16valve timing marks
Hi I got problem with a Nissan sarbe 160gxi after the head gasket blown i send the head to get sorted out the car don't have a same power I'm not sure if the guys set my cams right . I feel the timing on plug leads r to advance its pining . It was also low on gas . 156 km
Mar 25, 2012 | 1995 Nissan Sentra
Images of the timing marks to a 1994 1.6L nissan motor
dont have images but just can still help. ensure the motor is at TDC turn cam/cams by hand until all the valve over the number 1 cylinder are closed. your valve train is now in time.
Mar 13, 2012 | 1994 Nissan Sentra 4-Door
I need diagram of timing chain marks for a 02 nissan sentra with a 1.8 liter
Here are the diagrams showing how to set the cam timing.
Jan 04, 2012 | Cars & Trucks
How do you set the timing on a 94 Nissan Sentra?
There is 3 marks on the timing chain, 2 are exactly 16 links apart and the other is 22 from either of the 2. The engine should be at top dead center. Line the 2 (16 apart) marks with marks on your cam gears and the 3rd with your crank gear. Torque cam bearings to 100 inch lbs.
Feb 03, 2010 | 1994 Nissan Sentra 4-Door
Cam shaft timing marks
twin cam or single? if it's single the cam gear has a notch on it it poits to top bottom crank points to 0 mark the #1 piston at TDC distributor pointing to #1 on cap and your set.
Jun 28, 2009 | 1995 Nissan Pickup
WHAT IS THE PROPER TIMING ON A NISSAN 2400 1992
whyknot87: As far as I know, Nissan did not put a 2400 in a Sentra in 1992 or for that matter any year that I am aware of.
The Sentra had an SR20DE Which was a dual overhead cam engine.
According to Nissan, setting the timing on this engine requires the use of a scan tool as part of the procedure. There is no procedure for setting it without a scann tool.
The timing for this engine is 15 dedrees +/- 2 degrees @700RPM
The other engine this year Sentra used was a GA16DE
which was also a dual overhead cam engine.
This one could be set in a conventional manner with a regular timing light. You must have the engine at normal operating temp.
Disconnect the throttle switch and then you set the timing to
10 degrees +/_ 2 degrees @700RPM
The 2400 engine you probably are referring to is the KA24DE which came in Nissan 240SX and the Nissan Stanza. There are procedures for setting these as well, however I need to know wha4t car and engine you have?
The 2400 had 15 degrees +/- 2 degrees @700RPM
Apr 10, 2009 | 1992 Nissan Sentra 4 Door
Audi 2.8 Timing Belt Kit A6 Logo
82 people viewed this question
Top Aftermarket Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Aftermarket Vehicle Part and Accessory Expert? Answer questions, earn points and help others
