Question about Insignia Televison & Video
Insignia tv issues
TV was working fine last night. Got up this morning and there is an error message HDCP-019-HDMI port error. Sound works but no picture.
    Top Expert:
  • Insignia Master
  • 42,874 Answers
Your Insignia TV probably has had an internal power supply failure
Posted on Oct 13, 2013
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
get-it-goin
  • 85 Answers
SOURCE: 42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Posted on Feb 27, 2009
  • 4 Answers
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Posted on May 18, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
  • 30 Answers
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Posted on Sep 26, 2009
Testimonial: "A quick one to respond with a good answer to the problem."
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
Vsx-1122
Did you take the default configuration when you set up the device? Did you change anything? Go back to the setup and see if you have modified any of the output sections. Also check for the TV being plugged into the wrong place...
HDCP is "High-Bandwidth Digital Content Protection" via HDMI connections, I believe. In short it's saying that it has some kind of error that is a copyright violation, as a guess. You might look it up on the Pioneer site for a better explaination.
Jack
Aug 06, 2014 | Pioneer VSX-1122-K Receiver
32D20 connection problems
You could have a HDMI cable that has gone bad; FYI, HDMI cables carry both audio and video signals.
Regarding the "Not HDCP Compliant" message: http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
Dec 28, 2013 | Hisense Televison & Video
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
Hdmi port not working on plasma tv
Contact the authorized service center to rectify this fault. In most cases, the main board might need replacement.
Jul 23, 2013 | Insignia 42" LCD Flat-Panel HDTV
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Apr 11, 2009 | Yamaha RX-V461 AV Receiver
Phillips plasma 50 inch HDMI cable port being blocked by cable Cable company will not do anything. Cable box explorer 8300hdc It will run for a day or two then the cable port stops working.
There are some ambiguities in the HDCP protocol (rights protection for HD).  When two devices use this one will send a message to the other, it then waits for a response, lastly it responds back.  This is the connection setup procedure.  The issue is that there wasn't a specified time limit that a device must wait before assuming the connection isn't working.  This can cause you to get an error message along the lines of "your tv doesn't support hdcp"  Unfortunately, there's not much that can be done about this.  I spent the better part of two weeks researching this issue with my own television and cable box.  I actually called the cable company and the contractor they use to link them to all of the relevant information but they still insist my tv has an issue.
On the other hand, if you're not getting a message like this you may need to clarify whether you are getting an error or if it's just completely blank.
Mar 13, 2008 | Philips Televison & Video
Televison & Video Logo
191 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
