Question about Braun Aromaster KF 400 Coffee Maker
I have a braun type 4085 and the rubber ball has fallen out and I am unable to find it I am looking for a replacement part no. and a place to order the part from.
2 Suggested Answers
SOURCE: A small part of my Braun type 4085 coffee maker
The rubber ball is the stopper at the small opening under the funnel. When the pot is removed from the unit, the stopper closes to keep liquid from dripping on the warmer surface below. Try snapping it back into place so that the pin is facing towards the front of the machine. It may need glue.
Posted on Dec 26, 2010
I need a replacement rubber washer for my Braun blender; I think it's model Type 4184. Help, small thing, where can I get it? I'm in Kingston, ON Canada
Available parts for yourBraun 4184 blender can be found HH11&frmTyp=subgrp">here.
If the part you seek is not available suggest you contact their nearest service centre. You may search for the nearest service centre by inserting your postal code on this page.
Apr 02, 2012 | Braun Blenders
Braun 4000 series foils
You must be careful when ordering Braun '4000 Series' foils because Braun has made two different 4000 series shaver types that do not use the same parts. For this reason you must use your full model number or type number to ensure that you select the correct parts. If you are having difficulty locating this number, see video at the link below from shaveroutlet.com
http://shaveroutlet.com/locate_model_number_tutorial/
Once you have found the correct number, you can properly select the correct parts. Below, you will find links to both types of 4000 series foils. Match your number to the list of compatible models on the item pages to select the correct one
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-4700-series-tricontrol-foil-p-349.html
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/foil-fits-braun-4000-series-flex-control-twin-control-p-145.html
Jul 23, 2011 | Braun Health & Beauty
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
A small part of my Braun type 4085 coffee maker has fallen out and I don't know where it is from. It is a little round rubber ball with a stem out one end and a half of a circle on the other end. It...
Dec 24, 2010 | Braun Aromaster KF 400 Coffee Maker
I have a braun 5564 electric shaver i think the battery is dead can i get a new one and how do i replace it
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Oct 28, 2010 | Braun Flex XP 5614 Electric Shaver
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
My Braun 5564 electric/rechargeable razor will no longer hold charge. Suggestions please on repair or battery replacement?
Feb 05, 2010 | Braun Health & Beauty
Part fell out of cleaner base
It's probably one of the support rubbers that holds the shaver in place, and keeps it from falling too low into the cleaner. It's probably broken, but maybe you could put it back in place. There are two of those rubbers in the cleaner on the side where the trimmer is faced. If they both are broken, the shaver will fall too low, and the electric contacts on the top will also not fit - no charging as a result. My Braun service rep. said that the whole cleaning unit will have to be replaced to fix this. My plan, however, is to try with some small screws before I throw the whole thing in the "broken parts basket"....
Jan 30, 2008 | Braun Syncro 7680 Electric Shaver
Braun Aromaster KF 400 Coffee Maker Logo
83 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
