Question about Kitchen Appliances - Others
Probe is open? Message on screen - Kitchen Appliances - Others
    Problem Solver:
  • 15 Answers
It means that the temp probe has no resistance and should be replaced.
Posted on Oct 14, 2013
Frigidaire oven FSC88B-4 shows "Err F3 " message. What to do?
F3 - Open/shorted sensor (RTD probe) connection.
Check the temperature sensor and the wires and plugs between the sensor and the EOC are good, replace the temperature sensor (RTD probe). If the sensor and wiring are good, the EOC would need to be replaced.
Nov 23, 2016 | Frigidaire Kitchen Ranges
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Model MX-PS5000
Open error mean there is no soldering probe been install. use your button to switch it to the other where your probe been installed. You will see on your display there is blinking bar, if that bar is on the right that mean you are using the right port and if that port is open or no soldering probe plugin it will give you an message which is "Open Error". Just use the button to switch it left or right.
Apr 24, 2014 | METCAL Soldering Station MX5000 Series
Display shows SHORTED PROBE
When lincoln pizza oven shows shorted probe, this is a fault message which is not difficult to solve. You only need to replace the probe and it will be ok. this means that the probe is kaput and should be replaced.
The probe is inserted in main pan chamber next to the burner.Open the back cover unclip the probe from the holder and pull it backwards into to the control box chamber.On replacing the probe make sure only the thin part wire like of the probe goes into the heating chamber. make sure that bulb remains inside the control box chamber otherwise it would go kaput again.
Aug 01, 2013 | Lincoln Impinger 1116 Gas Oven
What is an E3 error message
E3 FROST PROBE OPEN: Normal operation is allowed. Replace probe.
E3 FROST PRObE OPEN: Normal operation is allowed. Ohm frost probe. Replace probe if ohm value not read. If ohm value is present replace board.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
Dec 19, 2009 | Ovens
Set probe temperature
If i remember correctly i believe this is actually a wiring issue. you would need to turn the power off open the control panel. and look for a control board with the probe connection on it. there should be a tech sheet in the compartment to help you identify it however if it is the problem they would be purple wires on the connector that need to be reversed.
Nov 27, 2008 | Ovens
Error message
I have the same problem. It is caused by the thermister thermal probe going bad (open circuit). Delonghi wont sell you the probe which probably costa about $2, they want to sell you a new control panel for $93. You can replace it with another thermister and it works but it will probably be out of calibration.
Jul 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Set probe temp or remove probe
my oven keeps telling me to input a temp probe and it keeps blinking and its getting on my nerves.
Jul 13, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Appliances - Others Logo
118 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
