Question about Kensington Computers & Internet
I have a kensington KeyFolio expert no.K 39531ww. It's connected to an iPad 3 Bluetooth. Connection is on but I can't use the typing keys on keyboard. The only keys that respons to the iPad are: the lock key and the key to display the keyboard on the screen of the iPad. How can I unlock the keyboard to use the normal typing keys? Thanks.
    Problem Solver:
  • 7 Answers
You have to use the keys on your computer or just un connect them
Posted on Oct 14, 2013
4 Suggested Answers
  • 38 Answers
SOURCE: locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Posted on Aug 03, 2009
  • 547 Answers
SOURCE: keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Posted on Sep 20, 2009
ralphspc
  • 74 Answers
SOURCE: Will Kensington KeyFolio Bluetooth Keyboard for Ipad2 support a mouse?
yes
Posted on Jan 29, 2012
Numbers one two and three won't work on my Kensington keyfolio key pad
Kensington KeyFolio Pro 2 Removable Keyboard Case and Stand For iPad 4...
Can you uninstall it and reinstall it? Or install it for another tablet?
If you get same result and it's new, on warranty,Claim warranty If past warranty, ask how much should cost to repair it
Yo can get it in Amazon for 35 USD
Jun 07, 2015 | Kensington Computers & Internet
Kensington keyboard manual
Your model number isn't listed, but all published Kensington keyboard manuals are available at
http://www.kensington.com/manuals
My keyboard (model K39336) connected easily, so here's what I had to do. Ensure the Ipad Bluetooth is on in settings. Turn on the keyboard, and when you see a single blue light, press the connect button. The iPad will give you a four digit code to type in on the keyboard. When you type in this code, the iPad and keyboard become 'paired' and keyboard input is available whenever the keyboard is turned on.
Aug 18, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
How do i turn on the backlight?
The backlight color toggle and brightness keys are located to the left of the backspace bar.
Jan 16, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
Keyboard sync button flashes but will not link with ipad
my keyboard shows that it is connected to my iPad but I can't use my keypad it doesn't show up on the monitor
Jan 20, 2013 | Kensington KeyFolio Bluetooth Keyboard and...
How do I connect the key board to my iPad?
read the manuel. should do the trick.
make sure bluetooth is "ON" on the iPad.
Dec 28, 2012 | Kensington KeyFolio Bluetooth Keyboard and...
Where to find the @ key on the keypad
Hold down the Shift key and then press the number 2 key.
Mar 26, 2011 | Kensington KeyFolio Bluetooth Keyboard and...
When keyboard goes dormant after 15 minutes I can't reconnect without using a new connect code?
Hello.
Unfortunately, when reconnecting, you need to type in a security code. The system does not remember the code and save it. That is the design of the keyboard.
Hope this helps.
Feb 23, 2011 | Kensington KeyFolio Bluetooth Keyboard and...
Computers & Internet Logo
177 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
