Question about Pioneer DEH-P3100 CD Player
No sound unless the player is squeezed out of the dash with all wires still hooked up
    Top Expert:
  • Pioneer Master
  • 41,919 Answers
Check for wire(s) that get pinched when the radio is in place. Also check for obstructions inside the radio cavity that may be interfering
with the radio in its installed position. Check for problems caused by mounting hardware. Check for poor connections, such as splices
Posted on Oct 13, 2013
Just hooked up dual xdvd710 but all it does is the button blinks red and beeps. What is wrong?
it sounds like a wiring problem i have seen these in many in dash dvd players. if you still have the manual just check your connections and your grounds there may be a short or mis matched wire
May 14, 2011 | Dual XDVD8181 Car Video Player
No sound
Make sure the wiring is proper.. Are all you wiring a brand new player into your car? If yes here's the wiring procedure..
all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Apr 12, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Only the back two speakers hooked up to my system are working. I am not getting any sound from the front two. Is there a way to adjust it so all four of them are playing
IF your balance is correct on your cd player and youve got good connections on both wires the speakers should work unless the front two channels are fried then theres no sound. I would try getting two extra pieces of wire 2 feet atleast and hook them up to the front two channels and to an extra speaker if youve got one then go from there.
Nov 25, 2010 | Dual Electronics XDMA6855 CD Player
I need help
considering that all the wires are hooked up right ,the HU is perfectly ok ,check whether the "Fader"is selected to the front speakers .
May 31, 2010 | Pioneer DEH-P4000UB CD Player
How do i by-pass the pb wire on clarion nz-409 in dash unit so my dvd player without damaging the goods
absolutely not......you run the parking brake wire to toggle switch positive and run the negative to a ground.
Dec 18, 2009 | Clarion Car Audio & Video
Turns on but nothing displays.
it sound like the memory wire is hook up wrong, check the yellow wire first then the red wire if still the same problem, connect the red and the yellow wire together to see if it come on it should come on you might have to run a hot wire from the battery in the dash then hook the yellow wire to it so your memory stays on
Apr 11, 2009 | Dual XDVD8170 Car DVD Player
1998 ford escort sound
check speaker wires on check connections
Mar 04, 2009 | 1998 Ford Escort
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
Aftermarket stereo install
Was it working before?
I would hate to have you crack it open when maybe the ground wires arent hooked up right. Unless you have a scope go online and get the manual on wiring it to ensure you did it right.
Nov 09, 2007 | Sony CDX-M630 CD Player
Pioneer DEH-P3100 CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
