Question about Frigidaire Affinity ATF7000ES Front Load Washer
Washer, shows welcome, but beeping code E91, how can I reset?
Error code e 91 for frigadare affinity dryer
most likely faulty control board...........
cheers
Apr 05, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
What's the meaning of E91,and F47 error codes on
Use Google to get the answer
GM/Cadillac OBD1 Codes E91 & F47
Aug 22, 2013 | Cars & Trucks
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Error Code E91
E91 is for the control board failure and needs to be replaced. Here is the part to order. To replace the board remove the top of the unit.
Dec 05, 2012 | Frigidaire ATF6000ES Front Load Washer
E91
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Atf6000es error code E91
Hi Angelia,
E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
Sep 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Hi I have just brought a Simpson Eziset model SWT604 It is constantly beeping every 2 seconds and showing Err in the display clock. I have contacted the repair people and think it needs to be reset/...
Thanks for choosing FixYa and welcome to the site Donna. Have you tried unplugging the washer for a few minutes and plugging it back up? If not, try that and it should reset. Is the washer refusing to start? Besides the code, what is the washer doing?
Apr 14, 2011 | Washing Machines
Need to know what these codes mean E98 E91 .EE ..E E52 1991cadillac deville
e52 is ecm memory reset
e91 park neutral safety switch
e98 transaxle shift fault
Jul 07, 2010 | 1991 Cadillac DeVille
My camera is showing e91 error and no flash
It is the falsh module that has broken and needs replacing. (probably not worth it on a W50 due to cost.
but try the following.
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash.
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Feb 03, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Washing Machines Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
