Question about Garmin GPSMAP 5212 GPS Receiver
My screen seams to be washed out can hardly see figs?
  • Garmin Master
  • 2,130 Answers
Any problems with the picture/graphics is usually attributed to a bad LCD display. Maybe the back light went out.
Posted on Oct 16, 2013
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Wiring diagram for 1999 ford mustang
Fig. Headlamps (1999) - ZOOM LINK
Check links...
Fig. Courtesy Lamps, Page 01 (1999)
Fig. Courtesy Lamps, Page 02 (1999, Coupe, Convertible/Hard Top)
Fig. Courtesy Lamps, Page 03 (1999, Convertible/Soft Top)
Fig. Courtesy Lamps, Page 04 (1999)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 15, 2012 | Ford Mustang Cars & Trucks
How to replace a dome light switch on a 1999 for mustang
Yes, you have one in each door frame;
Check links...
Yes, check frame door;
Check links...
My averatec will not turn on
Open it again and make sure you connect all the devices and such ..It seam to be like a clear case of a disconnected cable ..If the system boot up ..and seam to run ..try to see if the vga secondary monitor brings anything to a screen ..if it does it means you messed up with the monitor connections ..cause you changed the hard disk ..you don't have a operation system to boot into and try to make an idea..but its a start ..
Other things to check is the fan connections and cables ..
If the screen is totally blank I think is like I said just a bad connection to the monitor or a damaged cable in the process of opening it .In any other case you would have at least a warning on screen even without hard disk it should boot to BIOS ..
Dec 07, 2011 | Averatec Computers & Internet
My dishwasher is not washing. It runs water in and out, but is not washing. I hear the motor. The repair man told me that I would need top get to the chopper inside the dishwasher. I am not sure how to...
Appliance repair parts stores carry service manuals for individual brands if you need step by step instructions. The basic procedure is to disassemble the lower spray arm assembly down to the deck. If you attempt this, keep track of the placement of all components as you work downward. The chopper is right at the bottom under all of this. The usual problem found is the large screen at the bottom that becomes plugged with hard water and food deposits. Clean the screen in hot water, white vinegar, and detergent. The vinegar will take about an hour to dissolve the hard water scale. Check the spray arms for plugged spray holes and possible split seams. Look for blockage of any holes in the deck itself. Re-assemble in reverse order. Hope this helps!
Jan 07, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Need to replace heater core
Heater Core REMOVAL & INSTALLATION
1978 and Later Without A/C
  1. Disconnect the negative battery cable and drain the cooling system. CAUTION
    When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  2. Disconnect and plug the heater hoses from the core tubes.
  3. Disengage the electrical connectors from the module case.
  4. Unbolt and remove the module's front cover and lift out the core. To install:
  5. Install the core and apply sealant to the module cover, then install the cover and secure.
  6. Engage the electrical connectors to the module case.
  7. Remove the plugs, then connect the heater hoses to the core tubes.
  8. Connect the negative battery cable, then refill the engine cooling system and check for leaks.
1967 and Later With A/C
  1. Disconnect the negative battery cable, then drain the engine cooling system to a level below heater core. CAUTION
  2. Disconnect and plug the heater hoses at the core tubes. Plugging the hoses will help prevent excessive coolant leakage.
  3. Remove the module's rubber seal and screen. If necessary, disconnect the washer nozzle from the cowl.
  4. If necessary, remove the right windshield wiper arm.
  5. As applicable, remove or disengage, the diagnostic connector, high blower relay, thermostatic switch, ground strap and/or electrical connectors from the heater core module cover.
  6. Loosen the retainers and remove the module's top cover. The cover is sealed to the module and this seal must be broken before the cover can be removed. Be absolutely sure that all cover fasteners are removed before attempting to break the seal or cover damage will result. Take your time and be careful not to force and crack or otherwise damage the cover. NOTE: On many late model vehicles, cover interference with the vehicle's bulkhead will may removal difficult. On these vehicles it will be necessary to loosen the windshield's chromed lower trim plate for the necessary clearance.
  7. With the top cover removed, loosen or unclip the core retainer, then carefully lift the core from the vehicle. To install:
  8. Thoroughly clean the mating surfaces of the cover and the module of all old sealer.
  9. Install the heater core to the module and secure the retaining bracket.
  10. Apply a coating of sealant to the cover, then install the cover and tighten the fasteners. If the windshield trim plate was loosened for clearance, reposition and secure it.
  11. Engage the electrical connectors and components to the module cover, as applicable.
  12. If removed, install the right wiper arm.
  13. Install the module screen and rubber seal. If removed, install the washer nozzle to the cowl.
  14. Remove the plugs and reconnect the heater hoses to the core tubes.
  15. Connect the negative battery cable, then properly refill the engine cooling system and check for leaks. Fig. 3: Loosen the clamps, then disconnect the hoses from the heater core tubes 85946010.jpg Fig. 4: Remove the rubber seal from the module top cover 85946011.jpg Fig. 5: Loosen and remove the module cowl screen retainers 85946012.jpg Fig. 6: Make sure all of the screen retainers are removed, some like this one, are on the side of the screen 85946013.jpg Fig. 7: If necessary, remove the retainer and reposition the washer nozzle 85946014.jpg Fig. 8: Some retaining bolts may be partially hidden, check under the wiper arm 85946015.jpg Fig. 9: With all of the fasteners removed, carefully lift the screen from the top of the module 85946016.jpg Fig. 10: Disengage all electrical wiring and components from the top of the module 85946017.jpg Fig. 11: Loosen and remove the module top cover retaining bolts 85946018.jpg Fig. 12: As with the cowl screen, the top cover bolts may be difficult to find 85946019.jpg Fig. 13: If the windshield's chrome trimplate interferes with cover removal, it will have to be loosened or removed for additional clearance 85946020.jpg Fig. 14: Remove the bolt and bracket from the passenger side of the trim plate 85946021.jpg Fig. 15: With the bolt and bracket removed, the trim plate support may be removed for clearance 85946022.jpg Fig. 16: Once all of the bolts are removed, break the seal by lifting the top cover from the module 85946023.jpg Fig. 17: Remove the core retaining bracket; in this case by loosening the retaining bolt 85946024.jpg Fig. 18: Lift the heater core from the module, but remember it still may contain a fair amount of coolant 85946025.jpg prev.gif next.gif
Oct 13, 2010 | 1982 Chevrolet El Camino
Leaking fuel tank at seam under tank
That is the easiest leak to fix. You have to get a can of POR brand, tank repair. Remove the tank, drain it, dry it, I think you have to wash it with soap and water, dry it again, they give you instructions, mix up the paint, pour into the tank, let it cover the whole bottom, sides, and seam, and top too, and make sure you don't clog up any lines or vents, wait for it to dry, you will have the nicest looking finish inside your tank, hard as a rock, and will never leak again. I did my rust bucket Harley, the whole tank, came out beautiful. Then my Ducati sprung a leak right where yours is, and I did the same thing. It works great. Try POR.com.
Mar 14, 2010 | 2004 Yamaha FJR 1300
How can I tell if my blades actually spin in my dishwasher?
Place them in a known position and start a cycle. When you hear what should be washing action, open the door to see if the positions have changed and if water covers all of the interior. If they don't seem to have moved, you will need to tear down the lower spray unit to the deck noting the position and orientation of each part. There will be at least one screen that is probably plugged with food and hard water deposits--wash any screens in hot water, detergent and white vinegar until clean. Clean any openings in the deck itself that may be clogged with food deposits. Re-assemble in reverse order. Check both spray arms for plugged small spray holes and for split seams. Hope this helps!
Feb 18, 2010 | Dishwashers
The thread knots up under the feed dog on about the second stitch
hi! well, you can try to set up your thread accurately followed this
53de094.jpg fig.bobbins se up of thread.the thread should be clockwise rotation coming out to bobbins casing,insert thread on slot to acquired bobbins tension.after setting up you insert your bobbins on shuttle
casing.next set up your upper thread tension.on fig is just a sample.9cbc7d3.jpg follow the red thread set, try this on single straight sewing with dial stich set up to # 8 range to #17,Dial tension to # 3. use cotton/polyester foe sample sewing. try on hand maual sewing first several time before applying foot pedal to avoid needle breakage,
Mar 17, 2009 | New Home L-373 Mechanical Sewing Machine
Garmin GPSMAP 5212 GPS Receiver Logo
37 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
