Question about Panasonic DMR-E55 DVD Recorder
How do I connect my panasonic DMR EX769.. to my Panasonic TXL 32 TV? It just won't record...Help!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Are you trying to record off-air broadcasts?
Posted on Oct 27, 2013
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
  • 47 Answers
SOURCE: Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Posted on Apr 05, 2008
  • 8 Answers
SOURCE: Panasonic dmr-eh57 multi-region unlock code
I sent an e-mail to Panasonic New Zealand to ask about this, and they advised:
"Panasonic NZ no longer pre set DVD recorders or players for all region multi-zones.
However, we will multi-zone for all regions on request. This needs to be done by an Authorised Service Centre, as a special service remote is used. Once delivered to one of these agents, the service company will charge the fee to Panasonic NZ."
If you're not in NZ, try contacting Panasonic in your own country. Just call up www.panasonic with your country code after eg. US = .com and NZ = .co.nz. It seems a *lot* easier than all those complicated hacks on the net. Now all I have to do is work out how to disconnect my DVD recorder again, and try to
PS. I realise this question is 11 months old by now, but I hope my response helps someone like me just cruising the internet looking for help.
Posted on Jan 08, 2009
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
Factory reset Panasonic dmr-ex769
the reset facility should, logically, be in the general settings section of your tv. It may take some trawling through the various screens but it will be there somewhere
Jun 04, 2015 | Panasonic Televison & Video
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
Got a panasonic dvd recorder.dmr e55. need instructions to connect to television. have no manual. would like help to do this.
You may be able to download a free pdf copy of the manual online from the following site:
http://www.retrevo.com/support/Panasonic-DMR-E55-DVD-Players-manual/id/312dj185/t/2/
(just follow the prompts)
Pages 6 - 9 of the manual show connection of this unit to a TV and/or other equipment in some detail.
Apr 26, 2011 | Panasonic DMR-E55 DVD Recorder
DMR-ES35VS: How do I connect my Panasonic DMR-ES35V through a ...
Put the main aerial into the set top box,then take a male to female fly lead and connect it to your panasonic,then take another fly lead from the panasonic into the tv.If you have two scart sockets on each unit and the tv you can connect one into the tv from the box and one from the panasonic into the tv,then you can connect the box to the panasonic so you could record from the box.
May 05, 2010 | Panasonic DMR-ES35VS
Panasonic DMR-BS750EB recording Help needed
I also have the DMR-BS750EB its connected to a panasonic plasma via an hdmi cable and also scart lead so that i can use the tv freeview tuner to record as well and it works just fine if you still have the user manual check the advanced record features for external link or down load the user guide from panasonic. I have had mine since november and had no real issues ... except the ones ive caused from mis interpreting the instructions cheers Alex.
Feb 17, 2010 | Panasonic Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Panasonic dmr es10
What SCART connections do you have on each of the three units (TV, Virgin+ and DMR-ES10)?
Oct 26, 2008 | Panasonic DMR-ES10 DVD Recorder
Please help me with the set up of two Panasonic DVD recorders
To record and veiw DVD movie at the same time connect the DMRE55 RCA cable output to DMREZ25 input 1 then the DMREZ output to yout TV input. Then on the DMREZ press input select and select IN1 to record from the E55.
Nov 04, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
