Question about Samsung Office Equipment & Supplies
System initializing - Samsung Office Equipment & Supplies
    Scholar:
  • Samsung Expert
  • 113 Answers
Hi, most properly is the main board issue
Posted on Oct 14, 2013
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
Oil capacity on a 1991 geo storm
1991 GEO STORM 1.6L 4-cyl Engine Code 5 DOHCCAPACITIES
Engine, with filter.......... 3.2 quarts
Cooling System, W/ MT Initial Fill.......... 7.4 quarts
Cooling System, W/ AT Initial Fill.......... 8.0 quarts
Automatic Transmission, Initial Fill........ 4.3 quarts [1]
Automatic Transmission, Total Fill......... 7.0 quarts
Manual Transmission, ..........4.0 pints[1] With ENG at operating temperature, shift through all gears.
Check fluid level in PARK and add fluid as needed.1991 GEO STORM 1.6L 4-cyl Engine Code 6 SOHC
1992 GEO STORM 1.8L 4-cyl Engine Code 8 DOHCCAPACITIES
Engine, with filter.......... 4.0 quarts
Cooling System, W MT Initial Fill........... 7.4 quarts
Manual Transmission, .......... 4.0 pints[1] With ENG at operating temperature, shift through all gears.
Sep 12, 2012 | 1991 Geo Storm
How much oil does my 2001 silverado k3500 with 8.1 L gas engine hold?
All TEMPS......5W-30
Engine, with filter..........6.5 quarts [1]
Cooling System, AT Initial Fill..........20.8 quarts
Cooling System, MT Initial Fill..........21.2 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts [2]
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
4 speed 4L80-E..........13.6 quarts
5 speed 1000..........12.7 quarts
Manual Transmission, NV4500 (TOPC)..........7.9 pints
Manual Transmission, ZF S6-650..........12.7 pints
Feb 03, 2011 | 2001 Chevrolet Silverado 3500
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Initialization failed
You need to uninstall and Reinstall the particular game.. or try system restore for quick resolution
Feb 03, 2009 | Microsoft Windows 98 for PC
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
Freezes at system initializing screen
Please go to my blog to fix your problem. http://terminaltech.blogspot.com/2007/04/iriver-h10-freezing-at-initializing.html
Mar 14, 2007 | iRiver H10 MP3 Player
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e570. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Personal programs and data are permanently deleted from your Pocket PC’s. The factory pre-installed operating system Pocket PC 2002 remains intact. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow these steps: Turn off the power to the unit. Then press the power button while pressing and holding the reset switch with the stylus. Release the power button. When a screen appears, release the reset switch When initialization is completed, the "Welcome Screen" will appear. Set up the system according to the startup procedure as indicated by the on screen instructions.
Sep 08, 2005 | Toshiba e570
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
