Question about Lands Phones
Need a user manual for a cable and wireless CWt300
In need of a user manual for SBG6580 wireless router
The User Manuals for many of the Motorola modems and gateways are available from Motorola on their support site: http://www.motorola.com/Support/US-EN/Consumer-Support/Cable-Modems-and-Gateways . Select your model. On the next page, use the drop down menu to select User Manual in the Select A Topic drop-down menu. Then click Search. The direct link to the manual for the SBG6580 is http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG6580-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SURFboard_SBG6580_UserGuide.pdf . Note you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Oct 03, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Linksys manual
Click here Click on above link then you can download linksys E1000 router manual. You can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
How to find the security key? Can't lock it.
It maybe written on a label on the actual router - otherwise you will need to log into the router
  • to log into the router - connect to the router with a cable and then using Internet explorer type - 192.168.1.1 the enter - a setup page login screen will appear the user name and the password is admin
  • Now you can goto the wireless section and set a password - see the user manual below - chapter 4 - page36 - advanced settings
  • User manualhttp://support.gateway.com/s/Manuals/Desktops/8509437.pdf
Apr 12, 2010 | Gateway Wireless-G WGR-200 Router...
Wireless connection switch on
The combination key should be fn and f10 although our new laptop can not find any networks wirelessly even with this turned on so help on this would be appreciated
Apr 23, 2009 | Computers & Internet
I just purchased a D-Link 2.4GHz Wireless Broadband Router
U need to confirm that your router is connected to cable/DSL modem that has access to internet from ISP.
This is due to DI524 just a wireless router, u need to add in a modem for internet access.
Mar 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless internet connection
Hi, to connect to wireless you need to access your wireless router, by connecting it with a cable and access router control panel.
To access router control panel you need to type router IP number on Internet Explorer bar, once the router is connected, then enter user ID and Password.
Once you are in router control panel go to wireless settings and set up your wireless.
You find router IP and user/password on the router manual, follow instructions on route user manual to connect to router control panel.
If you need more help you can call the support number listed on the router manual, or get a chat on Fixya.
regards
Sep 11, 2008 | NetGear WGR614 Wireless Router
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
Apr 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless internet
The other unit needs a wireless adapter to talk to the router wirelessly
make sure that the wireless function is turned on in the router software ,
you need to enter an IP address in the internet explorer to get into the router, (this should be in the manual or printed on the base of the unit).
you will need to enter a user name and password, (read the manual for these), sometimes, admin admin ,or admin password)
if you used a security key, make sure it is in the wireless software, of the wireless pc/laptop
good luck
Terry
Mar 25, 2008 | Computers & Internet
Lands Phones Logo
120 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
