Question about Lands Phones
How to set up answering machine for a cable and wireless CWT300 telephone
4 Suggested Answers
SOURCE: uniden ucis-125 telephone
http://nsegainkc1.aliant.net/knowledge/docs/Repair/PhManuals/UnidenUCIS-125.pdf Above link to owners manual.
Posted on Jul 03, 2007
Chipstr
  • 153 Answers
SOURCE: I urgently need the manual for Digital Telephone
I've been able to locate one manual for this phone. It's offered on this web page: http://tiny.cc/261k0
Posted on Feb 02, 2010
SOURCE: Instructions for setting BT Freelance XC1500 quad telephone
i have BTFreelanceXC1500 PHONE I DONN HAVVE DDAIL TONE IN MY PHONE PLZ GIIVE SOLUTION
Posted on Jun 13, 2011
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
My linksys pap2 cannot ring the wireless set or a fax machine.
Try changing the power supply.
It could be unable to supply the neccery power...
Jan 15, 2013 | Linksys PAP2T
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Does the USB cable go into the LINE or the EXT connector for the X125
There is only one connector to hook the USB cable to on the back of the printer. You are probably confused with the telephone line connections. The telephone line from your telephone wall connector normally connects to the LINE in connector. A telephone line out to an extension or answering machine would be connected to the EXT connector.
See the quick set-up guide for how to set up your printer and make the telephone and USB connections.
Jan 30, 2011 | Lexmark X125 All-In-One InkJet Printer
How do you set up fax
connect cable from wall outlet to line 1 of the printer/fax
if u ra using the same line for fax and telephone u can connect a cable from line 2 to the telephone or telephonic answering machine. it will work fine, for further assistance mail me raaj_k001@mail.com
Jan 28, 2011 | Office Equipment & Supplies
How do i connect my hp 1240 fax\printer to my computer
The fax must be connected directly to the wall phone jack. Connect any other phone line devices, such as a telephone or answering machine, to the phone jack on the back of the fax
The phone line cable used to connect the fax must be a two-conductor (wire) phone cable, like the one that shipped with the fax. The fax may fail to send or receive faxes if the phone cable has more than two conductors. To determine how many conductors the phone cable has, look at the end of the cable. Most phone cable connectors are clear and you can see the number of wires
The Rings to Answer setting determines how many times the line will ring before the fax answers. Follow the steps below to change the rings to answer setting.
  1. Press Setup , press 3 , and then press 3 again to access the Rings to Answer setting.
  2. Press the Right Arrow to scroll through the available settings. When the desired number of rings is shown in the display, press OK .
To receive faxes manually, follow the steps below.
  1. Answer the phone like you normally would a telephone call. If the incoming call is from a fax machine, you will hear beeps or fax tones.
  2. Press either Start Black or Start Color to begin receiving the fax.
  3. Hang up the phone.
Jan 15, 2011 | HP 1240 Plain Paper Inkjet Fax
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have changed from a 2 line phone system to a 1 line. I am still using the same 2 line wireless telephone/answering machine. The telephone will only work for outgoing calls and not for incoming. The HP...
I just bought a used hp 3200se and am trying to use it as a stand alone fax. It (so far) does not answer incoming calls. I found that I can manually answer a fax call and then the machine seems to work fine.
I tried connecting to ...oh, by the way, I have digital phone service from Comcast, an analog line and it seems to work fine. So maybe the 6310xi is the same or maybe there are setting to deal with a digital line. Maybe something in this will help.
John Mavis
Nov 03, 2008 | HP Office Equipment & Supplies
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
