Question about Coffee Makers & Espresso Machines
Our Bosch coffee machine started making very weird loud noises in the middle of the night, out of the blue. Nobody used it the entire day, so it was on stand-by mode when the horrid noises occurred. The noises were persistent for quite the time, then a family member of mine switched it off, so the noises would stop. In the morning, as we switched it back on, it stopped making coffee. Like, the grinding begins, the beans disappear, then comes an irregular sound (not the loud one, more of like it's trying to do something, but can't. Like a printer with a paper jam or something), makes that sound twice, and then nothing happens. It does dispose the 'unused' grinded coffee though, where it's supposed to, as well as some water. We tried everything that was suggested in the manual, but, sadly, nothing works. What could be the problem?
    Top Expert:
  • Coffee Maker... Master
  • 34,255 Answers
Your Bosch coffee maker is in need of a serious overhaul or replacement
Posted on Oct 13, 2013
SOURCE: Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Posted on Aug 08, 2007
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
Grinder make a weird sound
Describe the weird sound. If it is very loud clacking like a machine gun type noise then vacuum our the hopper over the grinder and inspect for a stone jammed in there. The stones always look brown like a coffee bean, it is very common.
May 30, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
Breville making really loud noise when push espresso button
My machine started making a buzzing noise after the cleaning and descaling. It was still under warranty and I was planning to have it fixed by the manufacture but after a couple weeks of using it the noise stopped.
Feb 02, 2014 | Breville The Barista Express BES870XL...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
No water coming out makes noise and slite water and its not hot
Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
May 12, 2010 | Keurig Elite B40 Coffee Maker
My Keurig single brew has started making noise.
TAKE IT BACK! ! If it is only a month old and you still have the box and or reciept, it should be covered under warranty
Dec 28, 2009 | Keurig B60 Coffee Maker
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
