A while ago someone had a manual for easi logic 1300, anyone could maybe put this up again if they have it? Cheers
Dacor wall oven
Your tech is making it easy on himself, either he makes bank on the 1300 dollar repair or you back-out and let him off the hook.... Heat/ Temp sensors are nearly universal, so just about any RTD sensor will work in the oven, they are easily replaceable as well. Second, the logic control module is $269.40 at RepairClinic, I would start there- while installing the logic board, pull out the relay board and give it a close look in the daylight to see if any of the solder joints on the back of the board are cracking, burned, or otherwise failing- it is probably fine. Install the logic board and observe operation, the rest of those parts are likely not necessary- your tech sounds like a "Parts Changer Monkey," the old PCM.
Apr 12, 2016 | Dacor EO130SCH Epicure Discovery Wall Oven...
Tip
Garmin Nuvi 1300 Manual Download
Download Garmin Nuvi 1300 Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Manual for your Garmin Nuvi 1300 GPS?
Would you like a digital copy of the Garmin Nuvi 1300 Users Guide for easy searching of terms and quick reference?
The Nuvi 1300 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | GPS
Golf mk1 1300 car idle perfect but when driving its mising
Try a tune-up: distributor cap, rotor, plugs, wires.
Apr 08, 2012 | Volkswagen Golf Cars & Trucks
2000 Yamaha XJR 1300 starting problems
Hi, Nigel it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2000 xjr 1300
How to Tell if Your Battery is Bad in 3 Easy Steps
Yamaha XJR1300 Owner Manual
OEM parts for Yamaha
Yamaha XJR1300 99 Service Manual
Oct 12, 2010 | 2000 Yamaha XJR 1300
I have altec lansing pro logic speakers from my
Check that your computer doesn't have a microphone (internal maybe) and that it's not switched on.
Cheers.
Jul 08, 2010 | Audio Players & Recorders
Garmin Nuvi 1300 (and 1490T) won't start up
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Jan 16, 2010 | Garmin nuvi 1300 Car GPS Receiver
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Jun 21, 2008 | Heating & Cooling
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
