Question about Brother MFC 7420 All-In-One Laser Printer
How to disable the fax? - Brother MFC 7420 All-In-One Laser Printer
  • Brother Master
  • 8,064 Answers
Use a cancel button. Press the button for another function (copy scan, print pictures from a flash card. Turn machine OFF and ON again. If the telephone line is not connected to the MFC, the fax will not work.
Posted on Oct 13, 2013
How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
dear
the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
Thanks.
Mar 02, 2015 | Samsung Office Equipment & Supplies
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
How to disable my fax/tel mode? I can't receive any messages, because the fax keeps coming on after the third ring?
Disable the FAX auto-answer
Press the FAX button
  1. Menu/Set, 0, 1
  2. Use the up/down arrow to select Receive mode to be "Manual"
  3. Press Menu/Set
  4. Press Stop/Exit
Manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057875.pdf
Mar 15, 2011 | Brother MFC 420CN All-In-One InkJet...
Ricoh Aficio 2045, FAX delivery Report
Try pressing the USER TOOLS button and look for a reports menu.
Jan 21, 2010 | Office Equipment & Supplies
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
I have hp laserjet 3050 and i not able to receive fax
Hello Rupesh,
Following is the description for Error 232
A communication failure (comm error) has occurred between the two machines. OR The user at the remote machine may have pressed CANCEL. OR The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
  1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
  2. If the error persists, and error correction is in use for the fax session, disable ECM
Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
Follow the steps below to disable V.34 setting.
  1. Press Menu/Enter.
  2. Press the < or > buttons to select Fax Setup, then press Menu/Enter.
  3. Press the < or > buttons to select All Faxes, then press Menu/Enter.
  4. Press the < or > buttons to select V.34, then press Menu/Enter.
  5. Press the < or > buttons to select OFF, then press Menu/Enter to save the selection.
top
Disable or Enable the ECM
  4. Press the < or > buttons to select ECM, then press Menu/Enter.
  5. Press the < or > buttons to select OFF or ON, then press Menu/Enter to save the selection.
    NOTE: The default setting for ECM is ON.
Dec 20, 2008 | HP LaserJet 3050 All-In-One Printer
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother MFC 7420 All-In-One Laser Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
