Question about Ricoh Office Equipment & Supplies
Tray 2 sc502 error code - Ricoh Office Equipment & Supplies
Code error 061-315 copy not coming
change the laser and it will be done. please don trouble your self just do as i am saying.
. remove the cover were the paper falls when you are making copies and take off the front cover until you reach the laser unit and replace with a functioning one. if you want some more help contac me on my cell number 00258 846427869
Apr 27, 2015 | Xerox Workcentre 5225 / Copier, With...
Sc502 code number 2 tray error
Paper problem or lift problem in tray 2, remove and reload paper, cycle power. -Carl
Jan 09, 2015 | Lanier Ld345 Ld335 Copier Priter & Scanner...
What is error code 60.02
60.2 is a lifter motor error, this is the motor that lifts the paper into position when you push tray 2 in. They do fail. Restart the printer and watch the paper level on the front of the tray to see if it moves at all. Also listen for any chattering noise is it does lift. Sometimes if the metal panel in the tray that lifts is not moving smoothly this error can occur. Pull the tray out and on the right hand side you will see a geared piece of plastic, rotate it to see if the tray lifts when you do. If not the tray might be the problem not the motor.
Sep 16, 2014 | HP LaserJet 4250n Printer
Konica minolta c350 error code c204
C 204 Tray 2 feeder up/down abnormality.Check the M9 paper feed tray 2 lift up motor connector for proper connection,the PS15 paper feed tray 2 upper limit sensor actuator,the motor coupling.
Jul 27, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c0211 in bizhub c252
c0211 = Manual tray rise decent error - check PC14 lift up sensor, M2PC tray 2 vertical transport motor and also the tray 2 control board
Aug 15, 2013 | Konica Minolta bizhub Office Equipment &...
I got a error code C-0204 and I`ve checked the tray 2 and is everything ok, but i still receiving this message and i cannot print. Please any help?
C0204 as I see you already know is a tray 2 elevator failure. Meaning the machine does not see tray 2 lifting up the paper. This is usually caused by improper paper loading, elevator sensor failure or lift motor failure. You can still use the copier/printer if you leave tray 2 open and inch or 2. Just use the other trays until repairs can be made.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
Aug 13, 2010 | Xerox Workcentre 5225 / Copier, With...
How to reset my copy counter to my kyocera km-1500
Sorry you cannot reset your counter if you pass the 10,000 copies, if you are under you can, but just to let you know that you can reset the counter only for 1 time, you can do that by entering the maintenance mode of the machine and reset the counter.
hit 1087 twice it let you go to maintenance mode then start touch the screen up or down till you see the counter life reset, then hit start buttom, then highlight the buttom that come on the screen and hit start or reset and u will be fine.
to exit the maintenance mode hit reset buttom twice till you see 000 on the screen, then hit number 1 then start.
Best regards
Mar 01, 2009 | Kyocera Mita Office Equipment & Supplies
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
H code
not familiar with the model number but H codes usually refer to paper tray lift failure - H2 tray 2 etc.H1 tray 1- are all your trays working ?
Dec 23, 2007 | Office Equipment & Supplies
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
