Question about Samsung Refrigerators
How do you get this refrigerator to fit through a standard 36" door
  • 26 Answers
Remove the refrigerator doors is the first thing to do - if you need more you can then remove the inside door framing of the doorway your trying to get through
Posted on Nov 28, 2013
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
Dec 28, 2014 | Hisense RS731N4AC1 Stainless Steel 562 l...
What is the standard size of a residential front or side door?
Exterior doors are usually 6'8" tall and 32" wide
Jan 10, 2013 | Building Materials
Where is damper switch on my gallery series
The damper switch / door is between your two doors. It is the one part that allows cool air from the freezer to cool the refrigerator portion.
Jul 18, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Years ago I purchased a Kinkead Vista-Pivot Shower Door, model 1500-31, Silver. For a variety of reasons the shower didn't get built until recently. However the door opening is now 32.5 inches wide so it...
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Mar 16, 2011 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I bypass the water filter on a side by side Frigerdaire refrigerator. The filters are around $40 every 6 months. Is this something I can do myself or are there parts to do this with?
Have you considered just getting a carbon 1/4" inline filter? You can hook a standard one right to your water line and even though the manufacturer says they should be changed out every 6 months, they usually last about 12. Here's a basic one:
http://cgi.ebay.com/AICRO-GAC-IN-LINE-FILTER-2-X-10-X-1-4-FNPT-JG-FIT-/390180520853?pt=LH_DefaultDomain_0&var=&hash=item99ab36a9be#ht_500wt_721
Jun 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Bottom of freezer compartmant door has ice build-up. unable to remove wire storage bin. Frozen to the bottom of the unit.
you may have an air leak on the bottom of the door so you will get a buildup of ice.do a full defrost,check door seals fit,as a first step.
Jun 02, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Food spoils quickly
Place thermometers in the freezer and refrigerator. Freezer should be around zero. Refrigerator 36-40. 36 is better. Adjust your cold control (thermostat) to obtain the temperatures. Check your condensing coils. Are they dirty? Check your door gaskets. Are they sealing properly? Check door alignment. Do they shut properly? Good luck.
Jul 13, 2009 | Refrigerators
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
