Question about Baby Gear
Bebeconfort belt guide on the front of the car seat (egg) has broken - where can I source a replacement small blue plastic part?
  • Baby Gear Master
  • 1,629 Answers
Hi Jo
Please could you advise which country you're in so that we can best assist.
Posted on Oct 27, 2013
SOURCE: Cosco Buckle Broken
I need a new plastic buckle for my car seat straps
Posted on Sep 30, 2008
arimethia
  • 4 Answers
SOURCE: clean my car seat
Those pieces WILL snap out, it just takes a bit of effort. Both my son and the boy that I nanny for have this car seat and I have taken them apart for washing the cover a couple of times. Just make sure to remember where everything goes back to.
If you're having difficulty prying them up, try using two spoons. Wedge either the handle ends or the spoon ends under either side and use them to leverage the piece up.
Hope this helps!
Posted on Mar 27, 2009
  • 419 Answers
SOURCE: Maxi cosi tobi plastic part replacement
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: Creatis Fix Car seat. The blue seat belt guide on
If you contact this link, you will be able to purchase the part.
http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en
I hope this helps.
Posted on Nov 15, 2009
SOURCE: nania solo car seat missing parts
hi did u manage 2 get the replacement straps as i am in need of a replacement as well.?
Posted on Feb 20, 2010
Where can I get a replacement seat belt retainer guide to replace my broken one?
check the dealer spares department for the part. Contact the belt manufacturer on line to see if the part is available. Go to a wrecker that specialises in your make of vehicle and see if you can get one from a wreck
Oct 09, 2014 | Cars & Trucks
I need new seat belt latches. Dog chewed plastic off; belts won't lock.
Junk yard. Google "junk yard" and your location and you should get some hits. Or I like car-part.com. Once you get them, you should be able to access the bolt that holds them in place by moving the seat all the way forward (assuming that we are talking about front seats). There should be a plastic cover that "pops" off with a little influence. Remove bolt, install new/used part.
Apr 20, 2013 | 1999 Honda Accord
I need to replace my seat belt buckle, and i need to remove the front seat before i can replaced the broken buckle.
Your question isn't stating what kind of car you have, but to remove the seat in car or truck if you have bucket seats, it should only be 4 bolts and a wiring harness. There may be small plastic caps over the bolts. Once you get the seat unbolted be sure to find the wires and just unplug the connector. The seatbelt should only be one bolt, but may be a torx (star) bit. Bench seats have the same concept, but you have to unbolt both passenger and drivers side to remove them. Seats aren't too heavy either. Look heavy, but usually not in newer vehicles.
Mar 09, 2011 | Toyota Corolla Cars & Trucks
I need to remove my headrest to change my seatbelt guide ; i can t get headrest to come off. Thank you
Pull the seat fabric down in front to expose the plastic piece that the headrest bar inserts through. You will see a small wire clip inserted through plastic. Remove it by prying with small flat head screwdriver. Repeat on other side. Headrest will then slide out.
Jul 02, 2010 | 1997 Chevrolet Cavalier
I dont know how to install stereo speakers in my citroen saxo VTR near the rear seats. how can i do this?
First you have to remove the old ones...
You cannot just clip out the rear speakers, as the cover over them is attached to the rear panel (2 door Saxos)
In order to take out the rear speakers, from what I remember...
1) Take out rear seats
-Get yourself in the car through one of the front doors
-Once inside face toward the rear seat
-Reach for gap between where the upper and lower parts of the seat join
-Pull the bottom half up and towards you
-Once it is vertical lift straight up to detach from pivot
-Get it out of the car to give you space
2) Undo 2 bolts
- Having just removed the lower part of the seat there are now 2 bolts visible 1 located each side of the car, next to the rear speaker panel.
- Undo the bolts, they are long so require lots of twisting until free
- Remember where the washer sat and place in safe location out of car
3) Lift up rear window seals
- Open rear windows
-Lift up the rubber seal which lies on the bottom part of the window
-(It is attached all the way round the window trim, only lifting it up is neccessary)
4) Remover upper seatbelt bolts
- Locate rear seat belts (side belts only)
- Locate top of seat belt fixing point
- Remove circular plastic covering on top joint of each belt (1 each side)
- This reveals seat belt joint bolt (1 each side)
- Undo bolts and place safely outside of car
- (Same for front seat belts required)
- Locate front seat belts
- Locate front seat belt joints at top of belt.
- Remove circular plastic covering (1 each side)
- This reveals bolt (1 each side)
- Undo bolt and place in safe location
5) Lower rear seat
- Open the boot
- Clamber in
- Locate where rear seat meets plastic trim (each side of car)
- Locate small plastic lever (each side of car)
- Push small plastic lever towards the front of the car (both sides same time)
- Meanwhile push rear seat gently towards front of car (helps if have a friend)
- This will lower seat
- (You do not want seat lowered completely, once seat is free in movement leave resting in normal position)
6) Remove rear speaker panels (requires trusted + competant friend)
-Friend Get in car sit where rear seat was on driver side (for space)
-You sit front seat passenger side
-You locate where rear speaker panel ends beside front door
-You pull rear speaker panel away from end at door towards opposite side
-You will notice part of rear speaker panel detach from car
-Friend and You pull off remainder of speaker panel from its poppers
-Notice lump of plastic preventing complete detachment from car
-Careful to prevent damage Friend and You need to move rear speaker panel towards front of car and up
-Remember plastic will flex, but is also capable of snapping
-Manipulating this action will get rear speaker panel detached from car...although still on the seatbelts themselves.
Notice how speaker is joined to hidden part of rear panel, rather than metal body work.
To remove rear speaker undo the 4 torx screws holding speaker in place, alongside wire joint (wire with plastic adaptor at end)
Do what you needed to do, and then return car to normal state by effectively reversing the above instructions.
(I accept no liability for any action you undertake from following these instructions.....yadda yadda)
If any problems contact a Sax-p I.C.E section expert, or if incounter any difficulties that the above cannot solve, any car audio installer can help, alongside most garages, including Citroen Dealerships.
The instructions above probably took longer to type than to actually perform, estimated time for completion is 40mins-1 hour.
Oct 24, 2009 | Car Audio & Video
Seat belt stuck
Open small plastic access panel located between front and rear doors a few inches above floor. Disconnect the two wire connector (usually attached to car frame) and locate the male pin connector, usually 1 red and 1 blue wires. Run two long wires from a car battery negative post and positive post (battery on the car or separate.) Hold one wire against one pin of the connector and quickly touch the other wire against the remaining pin. This will cause the motor to turn in one direction. If motor turns in wrong direction simply reverse the wires until motor brings belt to desired position then quickly remove the wires. Reattach connectors to resume 'normal' operation after 'CAUSE' has been repaired.
Aug 27, 2009 | 1992 Ford Thunderbird
Holden commodore vz acclaim my06 remove front headrests
push in the button on the left headrest post and use a small piece of coathanger wire and do the same to the other headrest post. There is a small hole in the side of the plastic. Now pull up on headrest whilst doing this and it should come out.
Jul 08, 2009 | Baby Gear
Front passenger door lock wont work, seat belt light on
Sounds like the plastic clip that connects the lock has broken however regardless of fault the inner door panel has to be removed to diagnose and repair.It could also be inner door lock assembly.
Dec 28, 2008 | 1989 Pontiac Bonneville
Baby Gear Logo
48 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
