Question about LeapFrog Tag Junior
Tag Jr. won't turn on. - LeapFrog Tag Junior
How do I reset the blu dash jr 4.ok
press the home key, volume key, and power key hold for 10-15 seconds, when screen changes only release power key and continue holding volume key and home key. A menu will appear on your screen just follow instructions to do a reset. Good luck
Feb 18, 2015 | Blu Dash Jr 4.0 K Cell Phone
My daughters nabi Jr is showing that its loading but won't turn on
Try this
Remove the rubber case of the Nabi Jr. Then press the Volume + and the Power Button. Calibrate the screen. Wait for the calibration until it is completed. But if it is still frozen, press on the power button for about 10 to 30 seconds to shut it down. Then restart the device.
Jan 19, 2015 | FUHU nabi Jr. 5" Capacitive Touch Android...
How do i reset a blu dash jr 4.0 k phone? model part is D142k
There should be an option to reset your phone in 'settings'.
Back Up and Reset should give you the option to reset with no problems. As you enter this option, the last option here is 'Factory Data Reset'. Try this and let me know what transpired after....
Dec 21, 2014 | Blu Dash Jr 4.0 K Cell Phone
My tag reader won't say my child's name
The two responses to this question have nothing to do with the question! I have a similar problem. I have a brand new Tag, connected and uploaded books just fine, but in my case it doesn't say any name when turned on/off.
Apr 03, 2012 | LeapFrog Tag Reading System
Computer won't recognize tag Jr what do I do
Thank you for using Fixa.com,
Have you tried to check your firewall settings on your computer? If you are running any of the firewalls, please make sure you temporarily disable Windows Firewall on your machine. If this resolve the issue, kindly contact LeapFrog Customer Support.
Apr 16, 2011 | LeapFrog Tag Reading System
When is my battery charged, is it when the light flashes or when the light is solid green as i have lost the instructions
When you snap the Leapster into the charger, the green light should come on (solid green). When it has finished charging, the light should go out. I don't know why it would flash green aside from maybe a bad connection.
Hope this helps!
Mar 01, 2011 | LeapFrog ® Leapster®2 Recharging Station
LeapFrog Connect Application has encountered a problem and needs to close. We are sorry for the inconvenience. I don't know what to do. this is what I got both of my kids for Christmas and it doesn't work...
I would completely remove the software and reinstall it. I recently bought the Tag Jr after already having a regular Tag installed on my computer, and had to completely re-download everything. LeapFrog's website today also said that they were experiencing much higher than normal traffic, and some applications may not work as well or as fast.
Dec 25, 2009 | LeapFrog Tag Reading System
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
May 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
LeapFrog Tag Junior Logo
56 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
