Question about Dell Inspiron 1525 Laptop
Dell optiplex 755 starts, Error code 0141. Msg: Error code 2000-0141. Msg: No drive detected.
4 Suggested Answers
  • 115 Answers
SOURCE: Error code on start up 0141 Error code
you can go to Support website for eg. support.dell.com.
Posted on Oct 25, 2009
SOURCE: error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Posted on Nov 09, 2009
rulds2008
  • 3866 Answers
SOURCE: Dell Inspiron Error Msg 2000-0141 cannot detect Hard Drive
You might have a hard drive crash, Meaning the hard drive needs to be changed out in it.
This happends over time,heat,AGE and all other sorts of occurances. Hard drives to not last! period! The only fix here is to have the hard drive replaced with new. Now in this model the hard drive should be on the bottem of the unit under a cover. you take a screw driver and open that hatch and take the hard drive out. You can bring that to a local best buy or computer shop and have a replacement put in Around $89-150 bucks depending on size you get and brand.
Thanks I hope this helps you out please do be considerate and leave postive feedback and ratings for your free answer today.
Posted on Jun 14, 2010
Testimonial: "Thanks for your solution , it was really helpfull"
Error code 2000-0141 no drive detected
That error code references a bad hard drive. If you still have warranty call Dell support line as that code means Dell will ship you a new hard drive.
Other options are much more complex like booting to a utility (you have to buy this) which will scan your hard drive sector by sector and try to repair bad blocks.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
Hi, In my dell optiplex 380 desktop showing blue dump error which describes that ecode : 051 msg : 2000-0151 msg: Hard drive-1-incorret stats:3E no addition
Most cases the harddrive is faulty if with code the PSA+ 2000-0151 code means Hard Drive (d): - Incorrect status: (x) (s) etc...Caution:Remove any and all power sources Including but not limited to: AC Adapter, Battery, or Desktop Power Cord, before you remove or reinstall an item in your computer." So Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
Aug 11, 2010 | Dell OptiPlex 380 MT Desktop Computer...
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dell error code 0141
This is caused by the intel chipset overheating.
Your drive is usually ok, but the chip controlling the drive is too hot to function properly. Try blowing your CPU fan out with compressed air, then start using a laptop cooler to keep it cool and this problem should go away.
Apr 05, 2010 | Dell Inspiron 1525 Laptop
Laptop wont turn on
It means that the Hard Disk Drive that holds all your data and the WIndows Operating system is not being seen by the system BIOS. Remove and reseat the hard drive, see if it detects. If it doesn't then you'll be replacing the hard drive.
Nov 14, 2009 | Dell Latitude C640 Notebook
Error 0141 msg:error code 2000-0141
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Juice got spilled on my laptop, now when it starts i get an error code 0141 No drive detected. what should i do now? Error 0141 Msg Code 2000-0141 No drive detected at start up : no bootable devices Help...
you should have stopped using it first...get the battery out and have it dry in an airconditioned room for several days...I know you can't afford that..water is a sort of conductor and it short-circuits sensitive electronics.
Aug 11, 2009 | Computers & Internet
Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
Mar 14, 2009 | Dell Inspiron B120 Notebook
No bootable device
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1525 Laptop Logo
221 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
