Question about Husqvarna Freesia 425
No manual. how do I change needle position for 1/4" seam on a Freesia 425
    Champion:
  • 241 Answers
When set on a straight stitch using the stitch width button will change the needle position. If you have moved it far to one side you can use the mirror image to shift it to one of 25 positions.
Posted on Oct 13, 2013
SOURCE: I can't figure out how to shift the needle to the left
When topstitching using straight stitch the needle position can be adjusted in steps. The stitch width button(+), 0 is the center position, width 6 isleft needle position,width6 mirror image(diamond half clear and half black)is right needle position.
hope this helps, it is from the manual.
Posted on Aug 19, 2008
  • 5 Answers
SOURCE: The needle keeps breaking.
make sure the needle is set to the correct position
Posted on Feb 27, 2009
  • 201 Answers
SOURCE: how do I get the outside case off the husqvarna
I don't know about a Freesia specifically, but I saw my tech. literally rip off the front of my Designer 1 once - took me years to get over the trauma!! I think with most of these modern plastic machines, the various parts of the cover are clipped on. You just need to be brave, take a hold, and go for it. I would be sure to remove any "loose" bits and take a good hard look at which bit fits where first. Try jiggling the part you want to remove to see if there is more "give" in one direction than another. Also be prepared in case you accidentally break the lugs that hold the piece in place.
Posted on Oct 14, 2009
  • 201 Answers
SOURCE: settings for stippling
Lower feed dogs. Turn on Needle Down. Presser foot pressure on Darning setting. Don't forget to lower the presser foot lever. That's about it! Since you are going to be the feed dogs, it doesn't really matter if you have a stitch length set or not, but do have width set for "0". The spring loaded darning/embroidery/quilting foot is the best for stippling, but try it with any open toe foot you may have. Do a few samples first using the threads you intend using on your project because the tensions might need tweaking. Try to get the result you like by adjusting only the top thread tension. If you really have to adjust the bobbin too, put a small mark on the bobbin case where the "normal" position of the screw is so you can return to that when you are done quilting.
Posted on Feb 02, 2010
  • 111 Answers
SOURCE: I have a Freesia 425
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
Posted on May 07, 2011
Testimonial: "thankyou"
How do I move needle to left position?
I believe the Fresia does not go to the left.
Aug 17, 2014 | Husqvarna Freesia 425
How do i make buttonhole on viking freesia 425
Hello
See pagew 24 and 25 in the User's Manual. If you need to download a manual, here is the link
https://www.manualslib.com/manual/592717/Viking-Freesia-415.html
Happy buttonholing
Sewingirl/
Apr 05, 2014 | Husqvarna Freesia 425
Gathering stitch knots
try changing thread top & bobbin
change needle
clean under needle plate & in the bobbin area for lint or threads
May 03, 2012 | Husqvarna Freesia 425
Settings for stippling freesia 425
Jan 31, 2010 | Husqvarna Freesia 425
Jan 27, 2009 | Husqvarna Freesia 415
Jul 27, 2008 | Husqvarna Freesia 415
Sewing Machines Logo
69 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
