Question about Canon DR-7580
CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT STREAK DOWN THE CENTER. LOOKS LIKE THE IMAGE IS FADED APPROX INCH WIDE RUNNING VERTICAL. DOESN'T HAPPEN ON EVERY IMAGE
  • 3 Answers
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Posted on Jun 09, 2009
Could be dirty optics. More than likely this is the case.
Posted on Dec 11, 2011
  • Todd Baum Dec 11, 2011
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
When I'm scanning a document on Canon 7580 each page will show up on my computer screen with a slighly different margin (keeps shifting left to right). The document is being fed into the scanner...
Under CapturePerfect3, you can choose to deskew the scanned image while scanning itself. Also select 'Image only" radio button instead of 'Guide Plate'. The software will remove black borders around the image.
S. Mohan, Chennai, India
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
May 19, 2011 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Vertical line down the scanned image
Clean the glass with Isopropyl Alcohol. No solvents please
Mar 11, 2010 | Canon DR-2050C Path-Through Scanner
DR-7580 will pick up and scan, but the outcome is black. What can I do to fix it.
Check if you have selected proper brightness or contrast, it is better to select auto mode. If you peep into the scanning module along the paper direction you can notice a streak of light of the top module. This is to just ensure there is no hardware problem.
S. Mohan
Feb 17, 2010 | Canon DR-7580
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
Faded images canon Dr 7580
Clean the glass thoroughly. Try Automatic settings and try various contrast levels in mamual mode.
S. Mohan
May 03, 2009 | Canon DR-9080C Path-Through Scanner
380 people viewed this question
old marine
old marine
